kpinnc 13,745 #26 Posted November 15, 2022 9 minutes ago, dmoore said: The best mouse control by far..... So long as you don't give them Meow Mix. They tend to get lazy if you do... 1 2 Share this post Link to post Share on other sites
ebinmaine 70,780 #27 Posted November 15, 2022 1 minute ago, kpinnc said: So long as you don't give them Meow Mix. They tend to get lazy if you do... Me too..... 3 Share this post Link to post Share on other sites
kpinnc 13,745 #28 Posted November 15, 2022 3 minutes ago, ebinmaine said: our deranged canine. A decent sized cat will establish his dominance rather quickly. ...unless your dog enjoys biting a running tiller. Share this post Link to post Share on other sites
Jeff-C175 7,203 #29 Posted November 15, 2022 8 minutes ago, ebinmaine said: What were you using as a setup? Bait? Depth of water? Here's what I use... A small board hooked to the edge of the bucket near the wire that has the 'rolling can' smeared with Peanut Butter. Only need two inches or so of used anti-freeze in the bottom. Reminds me... I need to clean mine out, there's a few in there that have been getting 'pickled' for a couple weeks now... 2 Share this post Link to post Share on other sites
Southern_Secret 464 #30 Posted November 15, 2022 14 minutes ago, ebinmaine said: What were you using as a setup? Bait? Depth of water? 5 gal bucket about 5-6" of water, a brazing rod with paper towel tube a board and peanut butter 1 Share this post Link to post Share on other sites
ebinmaine 70,780 #31 Posted November 15, 2022 14 minutes ago, kpinnc said: A decent sized cat will establish his dominance rather quickly. ...unless your dog enjoys biting a running tiller. . It's what she can't help NOT doing... She has the terrier reflex of biting everything and shaking it but unfortunately is not able to exhibit any control or choice. She's not aggressive. She's intensely reactive. We've had her tested multiple times. We've had multiple professionals try to help. Trina is quite the dog whisperer herself. This dog is just... Not set up quite right. Around home with humans larger than about 10 years old she's probably the best dog I've ever had. So last fall we came to the unfortunate conclusion that she will no longer be allowed out in public unless we honestly believe close proximity to other animals is nearly impossible. Sucks. But it is what it is..... 1 Share this post Link to post Share on other sites
ebinmaine 70,780 #32 Posted November 15, 2022 19 minutes ago, Jeff-C175 said: Here's what I use... A small board hooked to the edge of the bucket near the wire that has the 'rolling can' smeared with Peanut Butter. Only need two inches or so of used anti-freeze in the bottom. 14 minutes ago, Southern_Secret said: 5 gal bucket about 5-6" of water, a brazing rod with paper towel tube a board and peanut butter Try using the same bucket and same water but no rolling tube. No Bait at the top. Normally we put the bucket out near a stone wall. Prop a stick from a rock over to the top of the bucket. Maybe another stick going across the top. Cover the surface of the fluid that you use with a thin coat of black oil sunflower seeds. Rodents have poor, if any, depth perception and they can see and smell the seeds but not understand how far down they are. They jump in to get the seeds but obviously can't reach the stick to get back out.... 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #33 Posted November 15, 2022 (edited) 2 hours ago, ebinmaine said: black oil sunflower seeds Have you priced BOSS lately? OMG, they have doubled in price in a year, and a bit before that. Used to pay about 45 cents a pound or so, it's up to $1.00 a pound, and more. I'm not wasting any... the one I use works just fine! Used anti-freeze is in abundance and free. Edited November 15, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
WHGuy413 2,771 #34 Posted November 19, 2022 I picked up a few tecumseh h60 engines over the years for parts to keep my 603 running and almost every one of them had a mouse nest in the engine shroud and the bottoms were rotted out because of the mouse piss. The other place that I’ve had them several times is between the gas tank and dash as stated above by someone else. This usually ends up with chewed wires. 1 Share this post Link to post Share on other sites
Stormin 9,983 #35 Posted November 19, 2022 Rats can be the problem here. Property behind me and the one next to that used to keep birds. Parrots etc. Also put loads of scraps out for the wild life. No birds now apart from a duck. But still loads of food on and around the bird table. I now have a bait box by one of the sheds. Has holes in either end and two spikes inside. The bait I use is in a block with holes through to push down on the spikes. Not seen any rats for a while now. 1 Share this post Link to post Share on other sites
squonk 42,570 #36 Posted November 19, 2022 One of my boiler parts suppliers was in the heart of the city of Rochester NY. They had those bait boxes all over the place. One right by the front door. One time I went there and there was a rat sticking out the opening. six weeks later the same rat still in there! 1 1 Share this post Link to post Share on other sites
Rob J. 1,942 #37 Posted November 19, 2022 32 minutes ago, Stormin said: Rats can be the problem here. Property behind me and the one next to that used to keep birds. Parrots etc. Also put loads of scraps out for the wild life. No birds now apart from a duck. But still loads of food on and around the bird table. I now have a bait box by one of the sheds. Has holes in either end and two spikes inside. The bait I use is in a block with holes through to push down on the spikes. Not seen any rats for a while now. Yep, feeding the varmints is a big no no. It just leads to problems. Up north where I live we don’t have rats but chippys, squirrel, coon and bear. 😜 1 Share this post Link to post Share on other sites
Rob J. 1,942 #38 Posted November 19, 2022 I used a clothes hanger wire with a 20oz soda bottle with a hole drilled in the center of cap and bottom of bottle. Two holes at the top of bucket for the wire to go through. Smear with a little peanut butter and 6” of water in bucket and can use the sunflower seeds if you like but I’ve found they love that peanut butter and will crawl out onto the bottle where it spins and dumps them in. 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #39 Posted November 19, 2022 43 minutes ago, Rob J. said: water Used anti-freeze. Share this post Link to post Share on other sites
Rob J. 1,942 #40 Posted November 19, 2022 50 minutes ago, Jeff-C175 said: Used anti-freeze. Yeah if it’s winter but usually they move indoors somewhere by then. I get em before they hunker down for the winter. Before you could hear them in the ceiling rolling acorns around. Would drive me crazy. 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #41 Posted November 19, 2022 56 minutes ago, Rob J. said: rolling acorns around Mouse bowling league! Wonder what they use for pins? Share this post Link to post Share on other sites
ebinmaine 70,780 #42 Posted November 19, 2022 1 hour ago, Jeff-C175 said: Mouse bowling league! Wonder what they use for pins? #2 pencils. About ¾ worn out. 1 Share this post Link to post Share on other sites
