budman2 57 #1 Posted November 9, 2022 I have a 1996 520-H tachometer does not work nor the volt meter, does anyone know what controls these? Would like to get them fixed! Also in my fuse box the blue fuse is dead its a 10 or 15 amp, could this cause this? Thanks folks any and all help would be appreciated!!!! budman2 1 Share this post Link to post Share on other sites
953 nut 55,220 #2 Posted November 9, 2022 There is a 15 amp fuse that protects the wiring to all of those meters. You probably need to clean and inspect this fuse holder, it is near the battery and is subject to corrosion from battery acid fumes. 2 Share this post Link to post Share on other sites
budman2 57 #3 Posted November 9, 2022 I took the fuse block off and looked under it at the connections, no connections found to the 15amp fuse!! so I bought a new fuse block for it, getting ready to install it today, wish me luck not good at wiring!! Thanks budman2 2 1 Share this post Link to post Share on other sites
lynnmor 7,305 #4 Posted November 9, 2022 1 hour ago, budman2 said: I took the fuse block off and looked under it at the connections, no connections found to the 15amp fuse!! so I bought a new fuse block for it, getting ready to install it today, wish me luck not good at wiring!! Thanks budman2 Only 3 of the 4 fuse positions are used, perhaps the 15 amp fuse was in the wrong position. 1 Share this post Link to post Share on other sites
budman2 57 #5 Posted November 9, 2022 What do you mean by wrong position? 1 Share this post Link to post Share on other sites
lynnmor 7,305 #6 Posted November 9, 2022 3 hours ago, budman2 said: What do you mean by wrong position? You're serious, right? See your owners manual. Front to rear: Empty 15 amp 25 amp 30 amp Share this post Link to post Share on other sites
budman2 57 #7 Posted November 9, 2022 Never mind you don't understand what I am trying to tell you ok!!!!!!!! budman2 1 Share this post Link to post Share on other sites
budman2 57 #8 Posted November 9, 2022 Thanks anyways guys! I will get it done ok!!!!budman2 1 Share this post Link to post Share on other sites
budman2 57 #9 Posted November 19, 2022 Thanks to all you guys for you input!! found out that it wasn't the fuse block after all!! it was a defective ignition switch!!! God Bless you all and have a great weekend, budman2 3 Share this post Link to post Share on other sites
