case442
Toro 314 rear axle seal
case442
Hello All,
would anyone be able to give an axle seal part number and availability. Toro 314 with hydro
lynnmor
You can go to the Toro website to find part numbers.
gwest_ca
Here is the ipl. Once you have the Toro number go to the top of our Transmission section to some pined topics on alternative seals. Napa and SKF are popular sources.
Item #12 on this page
https://www.partstree.com/models/73403-314-h-toro-garden-tractor-sn-079000001-079999999-1997/hydrostatic-transmission-27/
Toro # 6449
Napa & SKF/CR # 11124 - The original seal is wider.
953 nut
https://www.ebay.com/itm/142042768245     Replacement TORO Wheelhorse Axle Seals Replaces 6449 (Set of 2
These seals are for :wh: Hydros with 1 1/8" axles. I have used them and the are a great fit.
JoeM
My best luck has been with the SKF seals. Stay away from old stock stuff. I have got some bargains and the seals failed after a running a while. Just think they were old and not pliable.
The metal housing on SKF seals are half the thickness of the OEM seal, and this allows the seal to be installed into the housing deeper and lets the seal run on a better part of the shaft. Plus if no thrust washer is used the seal will not be rubbed by the hub cause the axle floats a but in and out.
case442
Thank you very much everyone. I will order them up.
you are the best,
Mike
peter lena
@case442   https://www.zoro.com/palmetto-packing-packing-extractor-removable-7-12-in-l-1101/i/G2594417/?   make it easy to remove those seals , tiny hole in seal side wall , screw this in , and pop them out , picture is for reference , if you can get it locally / cheaper ,  do that . while you are there , look over related areas , pete
case442
Thank you Pete
