TonyToro Jr. 1,772 #1 Posted November 6, 2022 I’m wondering what this rear discharge deck fits? It looks like it wasn’t used much 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #2 Posted November 6, 2022 (edited) What does the underside look like . also rust seems almost nonexistent. Edited November 6, 2022 by The Freightliner Guy Share this post Link to post Share on other sites
daveoman1966 3,808 #3 Posted November 6, 2022 That rear disch deck model 05-42MR02 will hang on most any Horizontal shaft engine Wheelhorse / Toro made from 1973 to the last model year. (Will work on 1972 & older tractors if the belt drive system on THAT TRACTOR is modifed.) It has the pretty-much universal Tach-O-Matic attachment setup. Suitable for 10hp or more engine. It can also be converted to work on tractors with Vertical Shaft engines. 1 3 Share this post Link to post Share on other sites
TonyToro Jr. 1,772 #4 Posted November 6, 2022 Sooooo your saying it will fit on a C-145 2 Share this post Link to post Share on other sites
Jeff-C175 7,203 #5 Posted November 7, 2022 (edited) 21 minutes ago, TonyToro Jr. said: Sooooo your saying it will fit on a C-145 Absolutely. Same deck I use on a C-125. (used to live in S. Glastonbury) Edited November 7, 2022 by Jeff-C175 3 Share this post Link to post Share on other sites
TonyToro Jr. 1,772 #6 Posted November 7, 2022 Thanks guys for the help!!! 3 Share this post Link to post Share on other sites
peter lena 9,092 #7 Posted November 7, 2022 @ TONY TORO JR , nice deck , take care of it , with regular lubrication underside , break the grunge cycle , get some sun on the under side , get some hi temp lubrication in those spindle bearings , also the mule drive bearings . have 3 of those , all sleeping now in lubrication , pete 2 Share this post Link to post Share on other sites
TonyToro Jr. 1,772 #8 Posted November 7, 2022 2 hours ago, The Freightliner Guy said: What does the underside look like . also rust seems almost nonexistent. I don’t have any other pics of underneath but I probably have some later this week 1 Share this post Link to post Share on other sites
peter lena 9,092 #9 Posted November 7, 2022 @ TONY TORO JR . this what my decks look like , picked up a like new one years ago , that still looks new , most important thing to do is break the rot / dampness cycle . note the angle that the deck is propped up on to the sun , that heat , dries it out and sucks in the metal lubricant . have a regular , maintenance routine that I do , also make sure to end season with it , so its clean , dry , lubricated soaking , over winter . also rub down outer paint areas with penetrating oil rub down , preserves paint / saves paint . do a detailing greasing with lucas hi temp grease , on all related bearings . decks run with out noise or effort . pete 1 Share this post Link to post Share on other sites
TonyToro Jr. 1,772 #10 Posted November 7, 2022 Thanks for the info!!! 1 Share this post Link to post Share on other sites
