Pullstart 64,582 #1 Posted November 6, 2022 @formariz what do you think about this? It might not work for a wood worker like yourself, but for a novice? 1 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #2 Posted November 6, 2022 Interesting... but it would be nice if each project didn't take half a bottle of crazy glue... Don Share this post Link to post Share on other sites
wh500special 2,249 #3 Posted November 6, 2022 Pretty neat set of solutions. FWIW, the superglue (cyanoacrylate) isn’t reacting with the wood as the video title suggests. It’s reacting with the water in the wood. Which is why it sticks so quickly and tenaciously to skin and eyes. The reaction is quite exothermic (liberates heat) and you can see the water vapor coming off the material in some of the shots as a result. At a previous employer, we used a lot of superglue. We bought it in 55-gallon drums. They had to be corked up and vented with dessicant to keep them from turning into a smoldering block of plastic. The YouTuber has some more cool superglue videos on there too. Thanks for pointing us to them! Steve 1 1 Share this post Link to post Share on other sites
formariz 11,994 #4 Posted November 6, 2022 Essentially the process has been used for ever but using carpenters glue instead. The draw back to filling imperfections this way is that the glue seals the wood wherever it is applied. If piece is to be stained or finished that area will not accept the drain and it will always be very noticeable. For large damage such as in the corner of board it’s always better to fit and glue an actual piece from the same board. Cool because it’s easy but yields less than desirable results. 5 Share this post Link to post Share on other sites
Jeff-C175 7,203 #5 Posted November 6, 2022 Take a look at Krazy Glue and baking soda. I rebuilt missing chunks of a mule drive knob with it. Very strong! Don't breathe those nasty fumes! It's not "only" steam! 1 1 Share this post Link to post Share on other sites
Racinbob 11,726 #6 Posted November 6, 2022 5 hours ago, formariz said: Essentially the process has been used for ever but using carpenters glue instead. The draw back to filling imperfections this way is that the glue seals the wood wherever it is applied. If piece is to be stained or finished that area will not accept the drain and it will always be very noticeable. For large damage such as in the corner of board it’s always better to fit and glue an actual piece from the same board. Cool because it’s easy but yields less than desirable results. My thoughts too. It will never accept stain. It's pretty cool and just for giggles I'll probably try it but only on something that will get painted. 1 Share this post Link to post Share on other sites
953 nut 57,969 #7 Posted November 6, 2022 On a wood turning piece (on a lathe) that begins to crack you can use superglue and sawdust from another species of wood to celebrate the natural tendency of wood move as it dries. When the piece is finished the cracks become a feature. 1 Share this post Link to post Share on other sites
rmaynard 15,927 #8 Posted November 6, 2022 6 hours ago, formariz said: Essentially the process has been used for ever but using carpenters glue instead... When I was building a cherry cradle for my second grandson, I could not find a wood filler that I liked, so I saved my sawdust from the project and mixed it with hide glue. I found that it dried without shrinking, was hard to see after sanding, and was easy to stain. A little side note; when my grandson was helping me sort through some bins of miscellaneous stuff in the shop a couple of weeks ago, he found a small glass bottle of light brown powder. Turned out to be the sawdust that I had saved from his cradle. 1 2 1 Share this post Link to post Share on other sites
JoeM 7,935 #9 Posted November 6, 2022 I was wondering if that would work with "fine corinthian press board" and viola, it is in there! Now a days real wood is priced out of the question! 1 Share this post Link to post Share on other sites
formariz 11,994 #10 Posted November 6, 2022 On the subject of filling wood to hide a fastener the result of such decision is more often than not much more obvious and unsightly than if fastener was exposed. We all know a casing for example was nailed in. Careful precise locating of nail along with careful setting and leaving it that way yields a better result than hiding it with putty. Most times the filler will show up through paint anyway and if piece is stained it will never accept stain the same way. Most smear the putty way past actual hole leaving a larger area that will always look different. If filling is a must in those instances a wax stick of the proper color is best after piece is finished. The filling of nails is a modern practice which is a mistake.It is almost always better to leave them exposed or even accentuate the fact that they are there. The advent of the powered nail gun was essentially the end of the fine art of fastener placing and the overuse of filler. Now one just indiscriminately peppers the piece with too many nails ALL placed where they should not be. A nail is an honest efficient way of fastening something. There is no shame in leaving it exposed. As a matter of fact in stained work by careful planned placing it can by itself be almost unnoticeable. 4 Share this post Link to post Share on other sites
stevasaurus 23,072 #11 Posted November 6, 2022 (edited) I have an issue with oak flooring in the Dining Room. After having it sanded and finished, it seems it had been sanded before. Now I get some pieces that break off because of the thinness of the wood on top of the notch. A video shows mixing Carpenter's Glue with sawdust, taping of the chip and filling...then sanding smooth...then finish. The Oak flooring with it's grain is dark and light. The areas are very small. I have saved a fair amount of Oak sawdust. I am thinking that I can stain the sawdust before mixing in the glue and when I refinish the floor again, it might hide very well. Again, these are very small splinters...not really big enough to cut out and replace, and not big enough to replace the piece of flooring. What do you all think?? The video's I have watched have not talked about staining the sawdust first. Curious about that?? Edited November 6, 2022 by stevasaurus 1 Share this post Link to post Share on other sites
formariz 11,994 #12 Posted November 6, 2022 Floor is now sanded to its extreme. The part with the groove now has been sanded to the point that the upper wall of groove is paper thin. As one steps on those areas more will break. Actually a bit dangerous. A large sliver of that in your foot is a painful thing. I have repaired numerous floors like that. All loose and breaking pieces removed and a long skinny Dutchman fitted in and glued. Only that part was refinished to match floor. Filling an area specially a large one with sawdust mixed with glue is never a good idea. It is not a structurally sound repair. It will not adhere properly to the surface it is mated to. It will eventually break off. There are epoxy fillers which are better for that.a properly fitted Dutchman of the same wood species is always a better option. 2 2 Share this post Link to post Share on other sites
