Wheelhorse#1 1,738 #1 Posted November 5, 2022 (edited) Anyone know of a good source for throttle shaft bushing for a Carter carb.The folks on flea bay want a arm and leg. Edited November 6, 2022 by Wheelhorse#1 1 Share this post Link to post Share on other sites
WHX?? 49,890 #2 Posted November 5, 2022 @ebinmaine does carbs maybe he knows? 1 Share this post Link to post Share on other sites
squonk 41,893 #3 Posted November 5, 2022 Hillman drawer at Ace Hardware. 4 1 Share this post Link to post Share on other sites
Achto 28,166 #4 Posted November 5, 2022 1 minute ago, squonk said: Hillman drawer at Ace Hardware They do not have 7/16" od x 1/4" id x 1/8" thick. They do have 7/16 x 1/4 x 1/16. Buy two & double them up. Works fine, last long time. 3 3 Share this post Link to post Share on other sites
oliver2-44 10,068 #5 Posted November 5, 2022 3 minutes ago, Achto said: They do not have 7/16" od x 1/4" id x 1/8" thick. They do have 7/16 x 1/4 x 1/16. Buy two & double them up. Works fine, last long time. Exactly what I use. 1 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,738 #6 Posted November 5, 2022 12 minutes ago, Achto said: They do not have 7/16" od x 1/4" id x 1/8" thick. They do have 7/16 x 1/4 x 1/16. Buy two & double them up. Works fine, last long time. Thanks Guys ,y’all never fail to help a fellow out ! Much appreciated ! 1 1 Share this post Link to post Share on other sites
ebinmaine 69,685 #7 Posted November 5, 2022 18 minutes ago, Wheelhorse#1 said: Thanks Guys ,y’all never fail to help a fellow out ! Much appreciated ! How many ya need? I can mail em out if'n you don't have a good local source. 2 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,738 #8 Posted November 5, 2022 9 minutes ago, ebinmaine said: How many ya need? I can mail em out if'n you don't have a good local source. Thank you! I just need a couple.We have a Ace here,I’ll go and check to see tomorrow if they have it. If not I’ll get back to you.Thanks for the offer . 3 Share this post Link to post Share on other sites
8ntruck 7,254 #9 Posted November 6, 2022 3 hours ago, Achto said: They do not have 7/16" od x 1/4" id x 1/8" thick. They do have 7/16 x 1/4 x 1/16. Buy two & double them up. Works fine, last long time. Might put a small dab of grease between the two bushings before putting them into the carb. The grease will act as a seal to help prevent a possible air leak that could drive you nuts trying to find. 1 Share this post Link to post Share on other sites
WHX?? 49,890 #10 Posted November 6, 2022 (edited) Someday I'm gonna mail you a bushel of carbs that need it EB @ebinmaine I have just had so much good luck with the knock offs I see no need unless I really really have to stay orginal on a resto. Yes sometimes the case but still to just get one moving. I know I know we have had this discussion before. The choke backwards on the knock offs for the big blocks can be an issue but for how cheap they are?? Last post here. Edited November 6, 2022 by WHX?? 1 Share this post Link to post Share on other sites
ebinmaine 69,685 #11 Posted November 6, 2022 8 hours ago, WHX?? said: choke backwards on the knock offs for the big blocks can be an issue but for how cheap they are? It's great that you're having good luck on the cheapos. Just wasn't my experience. FYI. Isavetractors does sell an import replacement carb with the choke cable the right way. I've seen 2 so far. They seem to work well. For the price of them I'd still rebuild an original one but the option is there. 4 Share this post Link to post Share on other sites
Achto 28,166 #12 Posted November 6, 2022 I've always had good luck rebuilding the Carter carbs, even keep kits in stock. Have not tried the China carbs. Share this post Link to post Share on other sites
squonk 41,893 #13 Posted November 6, 2022 (edited) I have a Walbro on a K341 that I can't seem to find a kit # . Edit I think its 25 041 06S? Edited November 6, 2022 by squonk Share this post Link to post Share on other sites
pfrederi 18,157 #14 Posted November 6, 2022 (edited) 8 minutes ago, squonk said: I have a Walboro on a K341 that I can't seem to find a kit Do you need Walbro K1-WHG ?? Fixed jet?? Edited November 6, 2022 by pfrederi Share this post Link to post Share on other sites
squonk 41,893 #15 Posted November 6, 2022 (edited) 14 minutes ago, pfrederi said: Do you need Walbro K1-WHG ?? Fixed jet?? Not sure yet. This is on my neighbor's tractor. Kohler engine. Started running like crap. There is what looks like a mixture screw and an idle mix screw. If I take what looks like the mixture screw out gas comes out. I'm wondering if the float is shot Edited November 6, 2022 by squonk Share this post Link to post Share on other sites
pfrederi 18,157 #16 Posted November 6, 2022 Looks like this Share this post Link to post Share on other sites
squonk 41,893 #17 Posted November 6, 2022 This is the carb 1 Share this post Link to post Share on other sites
pfrederi 18,157 #18 Posted November 6, 2022 It is adkustabke but I wonder if the float valve and little spring are the same... 1 Share this post Link to post Share on other sites
