Tuneup 1,433 #26 Posted November 21, 2022 1 hour ago, Jeff-C175 said: This is what USCARBS says works on the K301. Tri-fuel too! $187.00 Interesting! Might be neat to try on a tractor. https://motorsnorkel.com/product/conversion-kits/k9522-tri-fuel-adapter-style-conversion-kit-natural-gas-propane-and-gasoline/ They're the good ones. Watch out for the diffusers that are basically a plastic gasket with a tube through it. The metal ones will allow for an efficient spray. All I had to do for my Chinese engine on my gen was to reduce the plug gap and it now can run on the 500 gallon tank, or the gasoline if I wish. 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #27 Posted November 21, 2022 35 minutes ago, ebinmaine said: tolerate the higher compression I believe this is because it is essentially a higher octane. I think I read 104 pump octane. Compression can be higher without detonation. 36 minutes ago, ebinmaine said: loss of power Which I believe would be approximately 10%. 37 minutes ago, ebinmaine said: VERY interesting Yes, it is! I guess a bracket could be fashioned to sit on the rear hitch to mount the gas bottle. Might want to build a 'bumper' around the tank to prevent damage if you are in the habit of backing into things! Now I'm pondering... do I want to do this? Duz any y'all know about the fittings on the various size tanks? The 20 lb gas grill tanks I'm familiar with, but if I converted the Generac generator I would want to use a 100 lb tank. Are the fittings on the valves the same? Or ???? I have a perfect place to install a 100 lb tank, outta sight, outta mind, outta view from the street, and a short distance to where I run the genny so hook up would be a breeze... IF the fittings are the same? 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #28 Posted November 21, 2022 (edited) ... DDPS ... ( Daggone Double Post Syndrome ) again! Edited November 21, 2022 by Jeff-C175 Share this post Link to post Share on other sites
Jeff-C175 7,203 #29 Posted November 21, 2022 30 minutes ago, Tuneup said: basically a plastic gasket with a tube through it That's what the one they show for the Generac is, a gasket with an intubation tube stuck down the engines throat. 1 Share this post Link to post Share on other sites
Handy Don 13,340 #30 Posted November 21, 2022 1 hour ago, ebinmaine said: Same here. My understanding is.... Propane/NG as a fuel has less energy than gasoline, which is what causes the power loss. The increase in compression is specific to propane/NG engines. Not tri-fuel. Propane/NG has a different burn rate than gasoline and can tolerate the higher compression. Increasing the compression in a propane/NG engine compensates for some of the loss of power caused by the lower energy output of propane/NG vs gasoline fuel. I've processed the thought in discussions with @Jrain and @Handy Don. I think I would be a VERY interesting conversion and workable Horse. I saw a large B&S Vanguard generator converted with a USCarb kit and the owner was delighted. That's what put me onto these. He had it on a dedicated natural gas line branched off his backyard "kitchen stove" and did accept that his max output was a bit lower than when it ran on gasoline. Except that I'm considering a larger backup generator, I'd already have converted my generator! Share this post Link to post Share on other sites
Snoopy11 5,717 #31 Posted November 21, 2022 1 hour ago, Jeff-C175 said: a gasket with an intubation tube stuck down the engines throat The kits that I have seen are exactly that. For whatever reason... I never trusted that setup... Don Share this post Link to post Share on other sites
