Similar Content
By CasualObserver
Good running 1984 GT-1800 with solid, quiet and smooth 48 inch deck. Original condition. Hydraulic lift works correctly. Great tractor. Pick up in Kasson, MN. Cash at pick up.
By Bill D
Can I change the hoses on my GT1800 without draining the transmission? Thanks.
By Bill D
I wanted a pedal control for my recently acquired GT1800. This is what I came up with. It still needs some finishing and I may rework the foot pedal. It's basically bolt on other than drilling a 7/8" hole in the belt cover. I'm also considering building an automatic neutral return if I can find the right torsion spring. I would appreciate any input and advice.
By Bill D
I've got an Eaton 1100 in a GT 1800. I noticed that it pushes quite easily after it had been sitting and not running for awhile. The manual says the transmission should lock up when pushed, but this one doesn't. I've had it running and it does move okay. It will lock up if you try to push it right after you shut it off? It hasn't been running in a month, and now it pushes easily. Is this normal or do I have a problem?
