"Manic-Mechanic" 1,228 #1 Posted October 27, 2022 (edited) I gathered up the best parts from two transaxles. All nice and lubed in 30w & assembly grease. (I'll install the hydro motor and last bolts after the transaxle is mounted...) Parking Pawl in Thrust Washer Dry fit 46T Dry fit 44T Held 46T aligned to the Differential and dropped down both, keeping 46T synced and through the Thrust washer Grade 8 5/16th's bolts, everything turns smoothly, no grit nor unwanted debris Parking Pawl engaged Disengaged Ready for the Gasket & 3/8th's Bolts, grade 5. Edited October 27, 2022 by "Manic-Mechanic" 6 Share this post Link to post Share on other sites
