llatja1@gmail.com 4 #1 Posted October 25, 2022 I have a 315 , 300 series. Was moving along and all of sudden it stop moving . The belt is on . I push the clutch in and the belt stops moving , I know that the clutch is working . Anyone have a idea what is wrong? 1 Share this post Link to post Share on other sites
Pullstart 64,471 #2 Posted October 25, 2022 It would be a good idea to verify your keyways are all intact. There is an input pulley keyway and your two hub keyways. Any of those could be broken or missing and free-spinning. 2 Share this post Link to post Share on other sites
wallfish 17,485 #3 Posted October 25, 2022 Or if the High/Low shifter was moved between gears. As in it's position is not engaged in either High or Low but in the middle 4 Share this post Link to post Share on other sites
llatja1@gmail.com 4 #5 Posted October 26, 2022 Thanks , I'll look at the key ways and check the high/low lever . Thanks agin t all. 1 Share this post Link to post Share on other sites
Lagersolut 722 #6 Posted October 26, 2022 How old is the belt ? Your 315 probably has a clutch damper - old stretched belts can bottom out the damper cylinder - your idler will not go back far enough to tension belt . My dampers all fell off replaced with old school spring . Share this post Link to post Share on other sites
953 nut 57,841 #7 Posted October 26, 2022 One more vote for the high-low shifter. I have inadvertently knocked it in between gears getting on and off a couple of times. 1 Share this post Link to post Share on other sites
