Toolmanbill 34 #1 Posted October 22, 2022 Had the tractor returned to me from the dealer after they had no luck repeating the no spark.started mowing and everything worked fine for about 30 minutes then the motor started cutting out when mowing.released pto and motor recovered.soon as I engaged pto motor would shut off.nursed it to the garage and everything went down hill from there.now none of the idiot lights work motor will not turn over seems as though it has no power at all.short in the wire harness? Share this post Link to post Share on other sites
953 nut 56,743 #2 Posted October 22, 2022 (edited) Never go back to that dealer; NEVER! The attached PDF has the wiring for each circuit which will make it easier to trace down the problem(S). Corrosion and loose terminals are the number one culprit. Edited October 22, 2022 by 953 nut 1 Share this post Link to post Share on other sites
rmaynard 15,801 #3 Posted October 22, 2022 (edited) Model number and year? Sorry didn't see the previous topic. Edited October 22, 2022 by rmaynard Share this post Link to post Share on other sites
Ed Kennell 39,735 #4 Posted October 22, 2022 4 hours ago, Toolmanbill said: .released pto and motor recovered.soon as I engaged pto motor would shut It looks like you found the problem. Check the two PTO safety switches. Share this post Link to post Share on other sites
Toolmanbill 34 #5 Posted October 23, 2022 THANKS guys for all your help.finally.I think I found the problem.jumped out pto switches and was able to finish mowing.will try to pickup new switches on Monday.really appreciate all your help! 1 2 Share this post Link to post Share on other sites
