squonk 41,071 #26 Posted October 21, 2022 21 minutes ago, Horse Newbie said: Where do you hook it up ? He has a Chilton manual for the truck… that would probably tell how, correct ? Directly to a port on the intake manifold would be best 1 Share this post Link to post Share on other sites
ri702bill 8,316 #27 Posted October 22, 2022 11 hours ago, Pullstart said: It wouldn’t hurt to read the spark plugs. That might tell which cylinder is acting up if it is isolated. When they read race car plugs, they shut it down fast from high rpms and a hard pull. This should be easier to tell which cylinder is suspect without high revs. I have not had to do that in years - decades actually.... Bill 1 Share this post Link to post Share on other sites
peter lena 8,610 #28 Posted October 22, 2022 @Horse Newbie had a similar issue on my grandsons ford ranger , engine PCV , VENT SYSTEM , was plugged solid , check valve fell apart at removal . removed all related hoses , opened up engine vent port , was clogged with shellac like build up , new hose , moved valve to an easier service area , it all worked out, also sea formed all related ports and carb itself . pete 2 Share this post Link to post Share on other sites
ri702bill 8,316 #29 Posted October 22, 2022 2 hours ago, peter lena said: also sea formed all related ports Ever add Seafoam a bit at a time directly into the intake with the engine running?? Looks like @Pullstart doing a burnout, but without the tire smoke smell !! Lots of white smoke, but it works. 2 2 Share this post Link to post Share on other sites
Pullstart 62,837 #30 Posted October 22, 2022 16 minutes ago, ri702bill said: Ever add Seafoam a bit at a time directly into the intake with the engine running?? Looks like @Pullstart doing a burnout, but without the tire smoke smell !! Lots of white smoke, but it works. ATF as well… my auto shop teacher taught me that one. You can easily add a qt to the gas tank, engine before an oil change. Direct into the intake, etc. 1 Share this post Link to post Share on other sites
ri702bill 8,316 #31 Posted October 22, 2022 Funny - the diaphragm on the old GM Powerglide transmissions would fail and suck all the ATF out of the trans !! Changed a few in my younger years....... 1 Share this post Link to post Share on other sites
