Rjay 3 #1 Posted October 19, 2022 hey guys, so kinda feel this is a stupid question but should i have the tractor running when i check the transmission fluid?? like you do for a car. 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #2 Posted October 19, 2022 Um well I would get I running before that but I guess it’s fine also welcome I wish you good luck with your project. kollin Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #3 Posted October 19, 2022 @Pullstart @Achto and thoughts or advice? Share this post Link to post Share on other sites
Pullstart 64,471 #4 Posted October 19, 2022 I’m not much of an Eaton specialist, but I believe as long as fluid has been pumping through, you check it without the engine running. @pfrederi @JoeM @19richie66 @lynnmor might know? 4 Share this post Link to post Share on other sites
Rjay 3 #5 Posted October 19, 2022 thanks guys . its my dads project. im just helping out with searching up questions he might have lol. 1 1 Share this post Link to post Share on other sites
Pullstart 64,471 #6 Posted October 19, 2022 2 minutes ago, Rjay said: thanks guys . its my dads project. im just helping out with searching up questions he might have lol. Share this post Link to post Share on other sites
19richie66 17,575 #7 Posted October 19, 2022 (edited) Manual say check oil while it’s cold. I have always checked it before staring it. Here is a copy of the manual. Just double click it. Edited October 19, 2022 by 19richie66 2 Share this post Link to post Share on other sites
JoeM 7,923 #8 Posted October 19, 2022 26 minutes ago, 19richie66 said: Manual say check oil while it’s cold. I have always checked it before starting it. Yes, cold, engine not running. Some of the 11's will back drain a little and can run out the dipstick. People add to them right after they are run thinking the oil level is low and then they are over full. The pump pulls off of the bottom of the sump and would have to get extremely low to do any damage. I like checking before the first start of the day. 1 1 Share this post Link to post Share on other sites
lynnmor 7,557 #9 Posted October 19, 2022 Check the oil with the engine off. If you change the oil or leave the tractor sitting for a long period of time, start it up and drive it forward and backward a bit, also run the lift up and down a few times to purge any air. Check the oil after it sits awhile. 2 Share this post Link to post Share on other sites
