gfullz
523xi Berco snowblower, how?
gfullz
Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
peter lena
@gfullz word of advise , take the time to detail lubricate the entire function of that , chances are those pulleys do not have a hi temp / stress grease in them , slowing down drive  function. notice that flat idler tiny bearing ? second picture , know for bearing failures , that belt transfer frame 1,st picture , could use a functional detailing , love to bring those set ups to life , personally replace , original grease , or pulleys with larger bearings , aerosol lubricant to make the rust run out. would set it up so you can hand move the drive belt function / action , make it move easier , that spring to idler pulley , should move with solid smoothness. look at the entire set up , each section is a hand off of drive power .  might find a  video on line , to show you ,  good luck , pete
gfullz
Thanks Pete - I will definitely lube everything up once I get some sort of confirmation that this sub frame is in fact the correct one for this tractor.... I'm just going by the fact that it came with the tractor, assuming that's the only reasonable explanation, you never know and I'm new to these for sure.
I'm also wondering what those left and right mounts were used for on the inside of the front wheels? I'm pretty sure they made a FEL for these but that may be a stretch.
After a second look at that small belt on the subframe it's indicative that this is not intended for this tractor... Looks like that would hook up to a vertical shaft motor and not the mule as that would require a much longer belt. I guess I could be missing something but....
Edited by gfullz
Pullstart
:text-welcomeconfetti:
The Xi machines are amazing!  The one downfall I have found, is the pivot pin.
please take a bit to inspect yours!
peter lena
@gfullz  did find a few  blowers on your model . look up 523xi  with berco blower , you tube etc , were showing earlier model tractors , just scan thru  what's out there , you might even find an installation site  . good luck . pete
gfullz
The issue is that there is nothing to be found for the 5xi with a berco. I've seen the vertical shaft tractors with the setup in a few vids but the xi and those models do not appear to have much in common. In browsing the berco manuals I can't seem to even find that identical drive mech. I see some brackets on the axle but I'm not sure any part of the blower subframe would even reach that far.
gwest_ca
This front idler assembly from the 2000 48" side discharge deck looks like yours.
https://www.partstree.com/models/78363-toro-48-side-discharge-mower-deck-for-5xi-garden-tractors-sn-200000001-200999999-2000/pulley-box-assembly-3/
Do you have the rear axle hitch?
https://www.partstree.com/models/100-3390-toro-rear-attach-a-matic-kit-for-5xi-series-garden-tractors/rear-attach-a-matic-for-garden-tractor-0/
Manuals for it
Get the frame under the tractor and see what lines up.
Many manuals here but model number required and possibly access to the French language.
https://bercomac.com/services-and-support/owner-manual
gfullz
Thanks Gwest - I do not have the rear quick attach. I'm thinking due to the logistics/orientation of the pulley's relative to the mule drive and blower that maybe the guy just assumed this subframe went with this tractor. I've looked at every manual listed for toro on the berco website and nothing looks familiar.
gwest_ca
I would contact Bercomac. I am sure they would help you.
Keep in mind New Holland also sold the 5xi tractors but blue in color.
  • Similar Content
    • Berco
      By Berco
      Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
    • kurm
      By kurm
      You can search for the specs but here are some links:
      https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en
      https://lookup3.toro.com/partdex/modlinfo.cfm?xCaller=Toro&o=2&x=22004&b=9900001&e=9999999&m=73552&y=1999&n=523Dxi Garden Tractor&channel=CN
      https://lookup3.toro.com/partdex/modlatch.cfm?xCaller=Toro&x=22004
      This is a beast!   Comes with the 60" deck and also a 48" deck and a new battery.  New belt (installed but unused), newer hoses, regular maintenance.
      There are wheel weights too but idk if they fit this unit as I've never tried.
      758 hours
      I got a zero turn and a Kubota tractor and this has sadly become ignored.
    • Berco
      By Berco
      I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
