formariz 11,994 #1 Posted October 18, 2022 I have big inclines in my property so when blowing leaves with tractor it’s faster to just go back and forth blowing them in same direction without turning. So I go up hill and then just let tractor roll back with clutch desingaged without putting it in reverse. Faster that way . My question is, am I doing damage to transmission by letting it roll back while pressing clutch without placing it in neutral? 1 2 Share this post Link to post Share on other sites
Jeff-C175 7,203 #2 Posted October 18, 2022 (edited) I doubt any damage could occur to the trans... but perhaps clutch wear is a 'maybe'? Edited October 18, 2022 by Jeff-C175 3 Share this post Link to post Share on other sites
Handy Don 13,340 #3 Posted October 18, 2022 43 minutes ago, formariz said: I have big inclines in my property so when blowing leaves with tractor it’s faster to just go back and forth blowing them in same direction without turning. So I go up hill and then just let tractor roll back with clutch desingaged without putting it in reverse. Faster that way . My question is, am I doing damage to transmission by letting it roll back while pressing clutch without placing it in neutral? I do the same on a short hill kinda like a "K" turn--turn and up a tractor length or two, clutch in, coast back turning the other way, brake to a stop, release clutch and off I go. 2 Share this post Link to post Share on other sites
Pullstart 64,491 #4 Posted October 18, 2022 There’s enough oil splashing around, it could likely roll 1/4 mile without any wear, even if the input shaft isn’t spinning. 2 2 Share this post Link to post Share on other sites
Handy Don 13,340 #5 Posted October 18, 2022 1 minute ago, Pullstart said: There’s enough oil splashing around, it could likely roll 1/4 mile without any wear, even if the input shaft isn’t spinning. Excellent point--the diff is still turning whenever the wheels are turning! 1 2 Share this post Link to post Share on other sites
8ntruck 7,378 #6 Posted October 18, 2022 I think the drive belt is at more risk than the transmission. 2 Share this post Link to post Share on other sites
Skipper 1,789 #7 Posted October 18, 2022 The trans don't care if it rolls forward or backwards. All turns the same, just opposite directions. Lubrication also good, so Same Same. One could actually argue that it is under less stress rolling backwards down that hill, than it was going up. 4 1 Share this post Link to post Share on other sites
953 nut 57,854 #8 Posted October 18, 2022 9 hours ago, formariz said: have big inclines in my property so when blowing leaves with tractor it’s faster to just go back and forth blowing them in same direction without turning. So I go up hill and then just let tractor roll back with clutch desingaged without putting it in reverse Engine oil starvation would be my only concern. If it is the 520 with a pressurized lubrication system it probably isn't a problem but a splash lube system would be of concern. 1 Share this post Link to post Share on other sites
oliver2-44 10,354 #9 Posted October 18, 2022 It might be a good idea to keep both the transmission and engine oil at the top of the full mark so theirs plenty of oil for the splash lube to sling around. 3 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #10 Posted October 18, 2022 I’m not sure how different chain and shaft drive is from pulley drive but I’m sure it’s probably not the best for em Share this post Link to post Share on other sites
Pullstart 64,491 #11 Posted October 18, 2022 @formariz what is your tractor/blower setup by the way? We all know @953 nut has a slick furnace blower that’ll give a small town a good breeze! 1 Share this post Link to post Share on other sites
formariz 11,994 #12 Posted October 18, 2022 45 minutes ago, Pullstart said: @formariz what is your tractor/blower setup by the way? We all know @953 nut has a slick furnace blower that’ll give a small town a good breeze! 1 2 5 Share this post Link to post Share on other sites
Pullstart 64,491 #13 Posted October 18, 2022 Is that a snowblower shute? Awesome! Share this post Link to post Share on other sites
formariz 11,994 #14 Posted October 18, 2022 5 minutes ago, Pullstart said: Is that a snowblower shute? Awesome! Yes it is. Fashioned after the one from @oldredrider serial #1. My favorite implement. Makes a job that was plain drudgery a real fun one now. 2 Share this post Link to post Share on other sites
Jeff-C175 7,203 #15 Posted October 18, 2022 Wish I had seen this last year before I disposed of two of those blowers! 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #16 Posted October 18, 2022 14 hours ago, formariz said: I have big inclines in my property so when blowing leaves with tractor it’s faster to just go back and forth blowing them in same direction without turning. So I go up hill and then just let tractor roll back with clutch desingaged without putting it in reverse. Faster that way . My question is, am I doing damage to transmission by letting it roll back while pressing clutch without placing it in neutral? I have MAJOR inclines on my property, and I do this all the time, (I'll be pushing dirt up a hill, and push the clutch in to let the tractor roll back down the hill). Absolutely no problem doing that... if there was a problem with this maneuver... all of my transmissions would be paper-weights... SOMETIMES though... if you are still rolling backwards when you release the clutch, you can get some air under the front tires... WOOOOOOHOOOOOO!!! Don 1 Share this post Link to post Share on other sites
stevasaurus 23,061 #17 Posted October 18, 2022 Cas, I doubt that you would hurt a manual transmission doing what you are doing. Maybe take it for a ride around the block after mowing to lube things up again if that is what you are worried about. I don't think I would want to do that with an auto transmission. 2 Share this post Link to post Share on other sites
Pullstart 64,491 #18 Posted October 18, 2022 3 hours ago, Jeff-C175 said: Wish I had seen this last year before I disposed of two of those blowers! Lincoln at A-Z Tractor used a snow blower housing to create a 3 point box scraper blade on the back of a C series… it was at the Big Show this year 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,498 #19 Posted October 18, 2022 34 minutes ago, stevasaurus said: I don't think I would want to do that with an auto transmission. Curious as to why? I don't have an auto but wondering what issue would be? Share this post Link to post Share on other sites
stevasaurus 23,061 #20 Posted October 18, 2022 @SylvanLakeWH not sure about that. I really have not had much experience with autos. My thinking is, it just may not be that good for an auto. They seem to be more temperamental and susceptible to not using them for what they were designed for. I may be wrong. Maybe, I should just shut up?? 2 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #21 Posted October 18, 2022 1 hour ago, Pullstart said: Lincoln at A-Z Tractor used a snow blower housing to create a 3 point box scraper blade on the back of a C series… it was at the Big Show this year I was talking about the furnace blowers though, but that's a good idea! 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #22 Posted October 18, 2022 1 hour ago, stevasaurus said: don't think I would want to do that with an auto transmission. I'm not sure you could do it with a hydro. They don't 'freewheel'. They don't have a clutch even! 2 Share this post Link to post Share on other sites
953 nut 57,854 #23 Posted October 19, 2022 I go back and forth all the time on our steep driveway when blowing leaves with the 418-C which has an Eaton 1100 and a Kohler Magnum twin with pressurized oil system. I wouldn't even consider doing that with a splash lubricated engine. It will not coast back, need to use the direction control and just slowly change direction. Share this post Link to post Share on other sites
formariz 11,994 #24 Posted October 19, 2022 I noticed that if I put lever in neutral and then let it roll backwards down the hill it goes a lot faster than if I just leave it gear and put clutch down letting it roll back. That seems to me that even though clutch is depressed transmission is still moving forward. Wheels are now moving in opposite direction. That is my concern if I make any sense. Share this post Link to post Share on other sites
formariz 11,994 #25 Posted October 19, 2022 @953 nut. Can you take a short video with it blowing leaves? I am curious as what the difference in pattern is from your set up to mine with the snow blower chute. Share this post Link to post Share on other sites
