t0urb0ss 2 #1 Posted October 16, 2022 Have model 73420 Wheel Horse. Clutch hangs up when depressed. Any suggestions why? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #2 Posted October 16, 2022 Item #53 is a gas/shock that may be at the end of it's life. Some replace it with a return spring on the left side of the tractor. https://www.partstree.com/models/73420-416-8-toro-garden-tractor-sn-039000001-039999999-1993/clutch-brake-and-speed-control-linkage-4/ Share this post Link to post Share on other sites
953 nut 57,841 #3 Posted October 17, 2022 4 hours ago, t0urb0ss said: Have model 73420 Wheel Horse. Clutch hangs up when depressed. Any suggestions why? If your right side foot rest is pushed in too far it will hang up on the clutch arm. Share this post Link to post Share on other sites
TonyToro Jr. 1,749 #4 Posted October 17, 2022 to !! Enjoy your time here 1 Share this post Link to post Share on other sites
Heatingman 971 #5 Posted October 17, 2022 Might just need a little grease on the involved linkages, and pivot points. 1 Share this post Link to post Share on other sites
Pullstart 64,471 #6 Posted October 17, 2022 I hear the gas shock thing far too often. I’d go with a spring, but check for lubrication opportunities and hang ups through the system. 1 Share this post Link to post Share on other sites
peter lena 9,086 #7 Posted October 17, 2022 @Pullstart agree with the spring and the lubrication detailing . making the rust run out tells a story . aerosol lubricant spray tube gets it in there , that entire set up is problem prone . it can work with total ease , pete Share this post Link to post Share on other sites
t0urb0ss 2 #8 Posted October 25, 2022 Finally got around to working on this. Shaft has wear on it, going to clean it up and smooth out worn areas. Hopefully with some grease and spring should solve problem. 1 Share this post Link to post Share on other sites
Handy Don 13,340 #9 Posted October 26, 2022 23 hours ago, t0urb0ss said: Finally got around to working on this. Shaft has wear on it, going to clean it up and smooth out worn areas. Hopefully with some grease and spring should solve problem. If the clutch cross-shaft has excessive wear as it passes through the two frames, it'll affect its operation. Fixes depend on location and amount of wear. 1 Share this post Link to post Share on other sites
