Tim Ziethen
8 speed transmission swap
Tim Ziethen
Can I swap 8 speed transmissions between two tractors?  I have one with 416-8 with a 1 1/8inch that is leaking badly and a 1 inch axle 8 speed transmission from a 312-8  that I am replacing all the seals so it will be good as donor.  Thanks
gwest_ca
As long as the brake linkage looks the same you are good to go.
Tim Ziethen
Thanks!  What is possible difference in brakes?
ri702bill
The difference that Garry is talking about is very apparent between a 6 speed and an 8 speed. You have the later style 8 speed - the brake AND parking brake should be the same- good to go!!
Bill
