Bow_Extreme 544 #1 Posted October 3, 2022 (edited) It’s taken me a long while to find, what I think, is the original wiring sleeve used on the Onan Twin, wire harness. I’m not an expert but I believe this is as close to original as one can get. The sleeve is made by, Techflex. Here is the link. Warning: It’s stupid expensive!! https://www.cabletiesandmore.com/silicone-electrical-insulation-sleeving?pid=5346 Anyone have better information or other products that fit close to the original? Edited October 3, 2022 by Bow_Extreme 1 Share this post Link to post Share on other sites
WHX?? 49,469 #2 Posted October 3, 2022 7 minutes ago, Bow_Extreme said: It’s stupid expensive!! Probably 'cause it's got a Mil spec which always jacks the price. BTW Bow I got a harness for ya if you want it. It was off @dclarkes frame off. Yours for shipping so pm me your address you want it. The one on top the box, the one with the gauges I gotta keep justice in case. Ther was a place I found it more reasonable. Try formtek? CRS ...I think that was the name. They had everything wiring related. 1 Share this post Link to post Share on other sites
Bow_Extreme 544 #3 Posted October 3, 2022 1 minute ago, WHX?? said: Probably 'cause it's got a Mil spec which always jacks the price. BTW Bow I got a harness for ya if you want it. It was off @dclarkes frame off. Yours for shipping so pm me your address you want it. The one on top the box, the one with the gauges I gotta keep justice in case. Ther was a place I found it more reasonable. Try formtek? CRS ...I think that was the name. They had everything wiring related. Thanks for the information. I will look them up. Also, thanks for the harness!! I will message you, shortly. 1 Share this post Link to post Share on other sites
peter lena 8,860 #4 Posted October 4, 2022 @Bow_Extreme the regular recurring wire / connection issues with those twins and later models with safety switches everywhere calls for a rerouting layout , when the set up was installed new , there was little thought of crammed / jammed / chafing wire issues . another major failure point is excessive heat . would insure more air flow / heat diversion to any problem spot . obviousely those multiple connection set ups were under strain / chafing . why not make a change ? the repetition of a problem is your greatest opportunity to make that problem go away . gone rogue so long , don't even think about NOT CHANGING IT , only me but every time it fails , its not going to get better by itself , pete 1 Share this post Link to post Share on other sites
Bow_Extreme 544 #5 Posted October 4, 2022 5 hours ago, peter lena said: @Bow_Extreme the regular recurring wire / connection issues with those twins and later models with safety switches everywhere calls for a rerouting layout , when the set up was installed new , there was little thought of crammed / jammed / chafing wire issues . another major failure point is excessive heat . would insure more air flow / heat diversion to any problem spot . obviousely those multiple connection set ups were under strain / chafing . why not make a change ? the repetition of a problem is your greatest opportunity to make that problem go away . gone rogue so long , don't even think about NOT CHANGING IT , only me but every time it fails , its not going to get better by itself , pete i appreciate the feedback and I’m very aware of the issues. I’ve rewired many 520’s and most of them are done differently. However, this project called for original restoration. It will be good for another 20+ years. 1 Share this post Link to post Share on other sites
