HambyeDon
WheelHorse B111 gearbox oil
HambyeDon
Just getting started on our B111.
Ran it yesterday and the gearbox is getting very hot and smells of gear oil.
How do I check and fill the box?
I cannot see any level or filler plugs.
oliver2-44
It probable a good idea to drain it and refill with 1-1/2 to 2 quarts of 80/90 weight gear oil. Any brand will do. If the old oil is gray milky colored or has water in it, it’s a good idea to flush it out with diesel or kerosene.  Also replace the rubber boot on the gear shift lever if it’s not in good condition.A bad boot let’s water in the transmission
953 nut
:WRS:                                    image.jpeg.0f552a9acf5f1d3fb04b46da4f6b9534.jpeg
Depending on the year and model number your B-111 will have a "Peerless 669" or a "Foote 4000-5" transmission. Here are the manuals for both of them. I have never owned either of these transmissions so this is about all the assistance I can offer.
Edited by 953 nut
  • Thanks 2
gwest_ca
The lubrication chart shows 24 oz. of SAE 90 for both the 4-speed and 6-speed Foote transmissions.
T2 in the chart
squonk
Peerless may have that nasty stinky Bentonite  grease in it.
Amazon.com: GENUINE OEM TECUMSEH PARTS - GREASE 1240X1 788067C : Patio,  Lawn & Garden
stevasaurus
Check your model number of your tractor.  If there is a "F" you have the Foote transmission, if it has a "P" it is Peerless.  :eusa-think:
