cerial 7 #1 Posted September 30, 2022 I have a 78 c-161 I picked up a wheelhorse snowblower for like $5 at a auction I just needed to get a new flag on the thing and it did just fine for the 2020-2021 winter. But the belt has seen better days and won't make it another winter. No markings to go off from left on the belt. Is this a correct replacment belt? https://www.amazon.com/REPLACEMENT-Wheel-Horse-75-9010-Snowblower/dp/B08LMRWYBP Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,036 #2 Posted September 30, 2022 May not be the thrower you have but the belt should be the same. Click on the picture to see it. 5/8" x 69" Share this post Link to post Share on other sites
peter lena 8,589 #3 Posted September 30, 2022 @cerial in addition to the correct belt above , take the time to free up and lubricate the idler pulley drive frame that the belt drives , usually has neglected , rough running bearings, easy to replace , and the frame mount movement points should be grease lubricated , anything to enhance the belt drive function , helps out , do you use a specific , open gear / cable lubricant on that auger chain drive ? 1/2" chain play on that ? done a lot of things to make that blower , work with ease . just some ideas , pete Share this post Link to post Share on other sites
