HambyeDon 26 #1 Posted September 29, 2022 Hello from France. We are English and living in rural Normandy,France. WheelHorse are very rare here and we are pleased to have just found a Belgian built B111. Looking forward to advice and help with our new tractor. 1 3 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #2 Posted September 29, 2022 welcome to the forum you’ll find lots of useful information about your tractor from some of the great people in this forum and I wish you good luck with your project. Kollin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,235 #3 Posted September 29, 2022 Welcome to Red Square This link will take you to 46 items on 2 pages for the B-111 https://www.wheelhorseforum.com/search/?&q=b-111&type=downloads_file&page=1&search_and_or=or&sortby=relevancy Share this post Link to post Share on other sites
Pullstart 64,452 #4 Posted September 29, 2022 Welcome Don! These manuals might not be perfect, being yours is from Belgium, but maybe they’ll help Share this post Link to post Share on other sites
Ed Kennell 40,414 #7 Posted September 29, 2022 to the Don Looks like that little B is ready to go to work. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #8 Posted September 29, 2022 Welcome Just as a suggestion , Change the fuel line and fuel filter . Share this post Link to post Share on other sites
sjoemie himself 3,072 #9 Posted October 2, 2022 Bonjour and You'll find lots of helpful info and people here. I'm relatively close since i'm from the Netherlands. Enjoy your time here on the forum and on your purchase ofcourse. Greetings from the Netherlands, Mark Share this post Link to post Share on other sites
meadowfield 2,650 #10 Posted October 3, 2022 welcome! we've had a few over here in the UK! Share this post Link to post Share on other sites
Stormin 9,983 #11 Posted October 11, 2022 Welcome to Red Square. Looks a handy little tractor you've got there. Be warned though. They breed. Share this post Link to post Share on other sites
Snoopy11 5,717 #12 Posted October 12, 2022 Looks like you have a 1979 model 92-11BF01. I looked at buying one of those a little bit ago. Here is some information that I think applies to your machine... (oh, and hi there! Welcome to Redsquare!) It's got a Briggs & Stratton 11hp 399cc model 252707. Oil capacity 1.5 quarts. It appears to have a Foote 4000 transmission... 6-SPEED DESCRIPTION: Foote Model 4000-5 Sliding gear Transmission; six speeds, with reverse LUBRICATION: Main Case: 24 oz. (700 gm)Shell Darina "0" Input Shaft Needle Bearings, Axle Cavities: pack grease with Exxon Unirex N-3 grease** TOLERANCES: Drive Shaft End Play: .020-.030 in. ( 5 . 7 mm) Intermediate Shaft End Play: .020-.030 in. Input Shaft End Play: .010-.020 in. (.3-.5 mm) Axle Shafts: Shim for minimum end play without binding Brake Air Gap: .020 in. (.5 mm) TORQUE VALUES: Housing Case Bolts: 80-90 in. Ibs. (9.2-10.4 Nm) Housing Center Support Bolt: 100-110 in. Ibs. (11.7-12.8 Nm) Reverse Idler Shaft Bolt: 80-90 in.Ibs. (9.2-10.4 Nm) Brake Shoulder Bolt: 200-250 in. lbs. (23.3-29 Nm) Shift Fork Screws: Back off turn from snug Apply Loctite 271 (Red) to threads of Brake Shoulder Boltand Shift Fork Screws I hope that helps! Don Share this post Link to post Share on other sites
953 nut 57,767 #13 Posted October 13, 2022 Nice looking B-111. Lots of great European members here to help you with parts sources to keep your out there in the pasture cutting grass. Share this post Link to post Share on other sites
