Pullstart 63,833 #1 Posted September 26, 2022 She gone. 2 5 Share this post Link to post Share on other sites
Handy Don 13,142 #2 Posted September 26, 2022 In systems we called that an "unrecoverable fault". 4 Share this post Link to post Share on other sites
rmaynard 15,846 #3 Posted September 26, 2022 (edited) I never did trust those sheet-metal ramps. Glad you weren't under the trailer when she blew. Now if the ramp had been made by Wheel Horse, it would have been all 1/4" steel angle-iron. Edited September 26, 2022 by rmaynard 1 6 Share this post Link to post Share on other sites
Pullstart 63,833 #4 Posted September 26, 2022 Thoughts were to Jack up the rear axle with purpose of servicing the front… then swap the ramps. Well I’ll swap that one to the scrap heap. 2 3 Share this post Link to post Share on other sites
ebinmaine 69,996 #5 Posted September 26, 2022 Perhaps that's the new "fold-for-storage" ramp set-up?? 3 Share this post Link to post Share on other sites
Alex175 784 #6 Posted September 26, 2022 Awww, it just wanted to give the tire a hug 5 Share this post Link to post Share on other sites
ri702bill 8,821 #7 Posted September 26, 2022 You evedently exceeded the design limit of the device !! Glad that you were not onder it at the time of failure. Way back in 1973, I worked in the Automotive garage of a chain Department Store. A retail customer bought a pair of Foxcraft ramps like yours (your now??) and oil & filter to do an oil change on his 2 year oil Buick. He got the car up on the ramps in the garage, but forgot the filter strap wrench in the basement. He crawled out, came back with the wrench only to find both ramps squashed flat. He tried to return them - we had to send him to the Store Customer Service area.... I recall we did his oil change for free ..... 3 Share this post Link to post Share on other sites
Jeff-C175 7,203 #8 Posted September 26, 2022 I've got an OLD pair of ramps that I can hardly lift anymore, VERY heavy material. I STILL don't trust them! ALWAYS use jack stands in addition. A guy I knew a LONG time ago was unfortunately killed when a ramp collapsed with him under the car. 4 Share this post Link to post Share on other sites
Pullstart 63,833 #9 Posted September 26, 2022 I crushed 2 more of my 4, just to make them unusable I think I’ll make a set out of wood, solid, not crushable. Maybe even bore a hole through both ends and make ‘em stackable and hang on a post in the shop! Share this post Link to post Share on other sites
The Freightliner Guy 1,334 #10 Posted September 26, 2022 (edited) I’ve done stuff that’s nearly killed me when I was working on my rj . Like when I push the front wheels on a makeshift wood ramp and at first I forgot to chock the wheels but then I chocked the wheels and wouldn’t you know it rolled back when I was under it so if I hadn’t chocked those rear wheels I’d be dead or in some cast’s Edited September 26, 2022 by The Freightliner Guy Share this post Link to post Share on other sites
Pullstart 63,833 #11 Posted September 26, 2022 I wouldn’t:t want to have an RJ roll over me, but I can’t imagine it would kill me either. Stay safe, especially under stuff! 3 Share this post Link to post Share on other sites
Jeff-C175 7,203 #12 Posted September 26, 2022 27 minutes ago, Pullstart said: wood, solid, not crushable I do have two 'blocks' that I use sometimes. They're not ramps, just stacks of 2x6 nailed together. Think solid non-adjustable jack stand. But I can see the advantage of making solid ramps out of 2X12 ... gonna be heavy, but isn't that the point? 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,804 #13 Posted September 26, 2022 I have a set of those plastic ones and they sure seem tough. Something like these: 3 Share this post Link to post Share on other sites
ri702bill 8,821 #14 Posted September 26, 2022 55 minutes ago, Sparky said: I have a set of those plastic ones and they sure seem tough. Something like these: Ihave the same pair bought from the same place - they work well. I also have a pair of PT wooden ramps my son and I built about 25 years ago. - no "bump stop" - we use a driver and a spotter to use these - and we DO use them Share this post Link to post Share on other sites
SylvanLakeWH 26,819 #15 Posted September 26, 2022 Regardless of type used, redundancy is advised. As @Jeff-C175 notes above, always use jack stands or equivalent… 1 Share this post Link to post Share on other sites
rmaynard 15,846 #16 Posted September 26, 2022 My cousin was killed when he was 18. He jacked up his car and stacked cinder blocks, not concrete blocks, under the axle, on their sides, not upright with the holes pointing up. They crushed and the car came down on him and crushed him. This was back in the early 1960's before the era of the litigious society that would have sued to have warning labels placed on cinder blocks. 5 Share this post Link to post Share on other sites
Jeff-C175 7,203 #17 Posted September 26, 2022 2 hours ago, ri702bill said: no "bump stop" Wow... that could sure cause some damage if you 'overshot the runway' ! One foot on the brake, one foot on the gas! 2 Share this post Link to post Share on other sites
Jeff-C175 7,203 #18 Posted September 26, 2022 48 minutes ago, rmaynard said: not upright with the holes pointing up Even if they WERE the 'right way', I would NEVER trust a cinder, or even a concrete block for that use. EVER... Sorry to hear about your cousin. 3 Share this post Link to post Share on other sites
ri702bill 8,821 #19 Posted September 26, 2022 2 hours ago, Jeff-C175 said: Wow... that could sure cause some damage if you 'overshot the runway' ! One foot on the brake, one foot on the gas! Not in my house!! It's ether a 4 or 5 speed standard 3 pedal setup - the "Millennial Anti-Theft Device" 1 2 Share this post Link to post Share on other sites
ri702bill 8,821 #20 Posted September 26, 2022 Yep -Kevin @Pullstart knows Exactly what I'm a'talkin' about... AND drove plenty of no brake cars into my FIL's garage that AAA dropped off in front of the house...!!! Share this post Link to post Share on other sites
Pullstart 63,833 #21 Posted September 26, 2022 (edited) My cousin’s 16 year old son recently drove his truck over these ramps. He learned how not to drive up them when they caved in the rockers of his rust free OBS Ford. I told him hat’s the cost of hot rodding, he wanted to cut off his exhaust and install an electric dump Y pipe Edited September 26, 2022 by Pullstart 1 Share this post Link to post Share on other sites
Handy Don 13,142 #22 Posted September 26, 2022 17 minutes ago, Pullstart said: 16 year old At that age we know everything except how much there is to know. 2 Share this post Link to post Share on other sites
ri702bill 8,821 #23 Posted September 26, 2022 32 minutes ago, Handy Don said: At that age we know everything except how much there is to know. And how much it costs to put your tail between your legs, act sincere and ask an ADULT to "fix" what you just ruined.. .. If handled correctly - priceless. If handled poorly - worthless... 1 Share this post Link to post Share on other sites
Shynon 7,474 #24 Posted September 27, 2022 10 hours ago, Pullstart said: Thoughts were to Jack up the rear axle with purpose of servicing the front… then swap the ramps. Well I’ll swap that one to the scrap heap. Make them out of wood, service station in town uses them 1 Share this post Link to post Share on other sites
rmaynard 15,846 #25 Posted September 27, 2022 7 hours ago, Jeff-C175 said: Even if they WERE the 'right way', I would NEVER trust a cinder, or even a concrete block for that use. EVER... Roger that. 1 Share this post Link to post Share on other sites
