D_Mac
C-175 Twin Automatic
D_Mac
Well fellas I may be going to the dark side. Going to look at one tomorrow. You know the story, ran a couple years ago when parked. Now no spark. Has mower deck with new blades and belt. Tires have new tubes. Has the plastic rear fenders/ seat pan that's busted up. I have no experience with the kohler twin. I know you like pictures but don't have any. Any helpful suggestions on what I need to look at tomorrow? Any idea what a replacement metal seat pan / rear fender unit will run? Worth ? I'd like to save it but really don't have the room for another but that's never stopped me before. Like to hear all your input. Thanks
  • Heart 1
SylvanLakeWH
Dark side??? :confusion-confused: :angry-tappingfoot: :angry-nono:
Love the Black Hoods!!! :ph34r:
No experience with the twins either, but other than the plastic fenders, which are an easy fix or swap for metal - cheap, they’re all great tractors… :twocents-twocents:
D_Mac
What do they swap with ? Any 300 .. 400... 500 series?
c-series don
I had a C-175 Twin Automatic with the factory series one 17hp Kohler. I’ll be the first to admit I’m not the best small engine mechanic in the world, but after 35+years of tinkering with small engines I gave up on this one. I just couldn’t get it to run perfectly, like I have others that I received that didn’t run at all.
  • Thanks 1
Jeff-C175
  On 9/25/2022 at 1:10 AM, D_Mac said:
Now no spark.
Points.  Probably corroded.
Mine's still going strong.
edgro
I have a C175, it's been my snow plow tractor for 25+ years. Series 1, always used on level ground. It has been a good tractor, burns no oil. I've replaced the coil, engine mounts, fender, and usual maintenance stuff. I have a 417A, same KT17, but series 2, bought with "engine problem, running on one hole". I lapped  and clearanced valves, replaced coil, and got it to run. Burns oil pretty bad, so it's a backup tractor for now. It had always been hard to start, thought it was ignition related. The fuel pump went out, an electric pump upgrade solved the starting issue. I recently got a second 417A, it was packed with mouse nesting under the tins, so I would look for that. This one starts right up, sounds good. Also just got another C175, bought as a parts tractor with an unknown engine problem. This one has the Sunstrand trans, the other C175 has the Eaton trans.
SylvanLakeWH
I’m not sure on all of them. Gas tank hole is the key line up on the two I have…
953 nut
I have a few twins and love the power and the sound of them. Clean the points with a crisp new $ 100 bill :scared-eek: (OK, could us an old $ 1 bill) and be sure that the coil "+" is getting 12 volts. No different than any other battery powered ignition system.
I would also suggest new fuel lines and an electric pump. The mechanical pump is on the top of the engine and can take forever to prime if it isn't in prefect condition.
pacer
I had one with the series 1 engine -- bought it with the comment "dont know whats wrong with it, it just wont start" $150 and I loaded her up. Problem quickly found coil bad, had seen a couple Harley coils in the local flea mkt and went and got 2 for $5. Ran like a champ.
Over the yrs here on the forum I seem to recall several posts with the coil being bad on the KT17 -- maybe that system likes to eat coils, might be a good thing to ck on this one.
D_Mac
Well I went to look at it this morning. I didn't pull the trigger. I think this was the first Wheel Horse I went to look at and didn't bring home with me. The rear fender/seatpan was so busted the seat couldn't be attached. The wiring was a mess. Mower deck was full of holes. I couldn't see paying his asking and he didn't want to budge so I walked away.
  • Like 3
Pullstart
Can’t win ‘em all!  I have a C-101 steel seat pan that is a direct swap for the plastic ones.  Or some day I’ll get rolling again on my GT-6.5 sheet metal project using a set of GT14 tins…
D_Mac
I may go back to it. What what a seat pan cost with the shipping ? Probably more then what I wanted to pay for the tractor.
Pullstart
Yeah, shipping something that huge (and vulnerable to damage) might not be the most efficient.  :eek:
squonk
Tractor doesn't run. How do you know if it doesn't have a knock in it! Automatic trans.can't drive it. How do you know if it's any good? Tractor doesn't roll easy. How you gonna get it on your truck? Unless he comes down some. PASS
D_Mac
I almost bought it just for the hub caps. I will keep pestering him as I know now his wife wants it gone. He said someone else had interest in it. We will see. If the back end wasn't so busted up I'd be more comfortable rolling the dice on it.
  • Similar Content
    • Maxwell-8
      By Maxwell-8
      So yesterday I picked-up a C175. She was rusting away as she was stored outside. She had a new to her Kohler K341. @squonk The previous owner indeed better had"LET AN ELECTRICIAN      CHECK his  SHORTS!"  as bad wiring shorted the battery out, and exploded/melted. She has a Sundstrand hydro pump with a Filter, is that normal? By the pump I believe it's a 1980. But you never now for sure as it's made in Oevel. Due to the bad wiring, the engine was in no running condition. But don't think the K341 has many hours on it. The hydro I don't know if it works. She was hard to push. So i lift up one wheel, so we could roll here one one wheel and the diff prevented the trans from locking up.
      So first things to do:
      1) get the engine running
      2) replace the steering wheel, but don't think removing it will be very hard as it's already split in two.
      3) replace the axleseals, the oil leak caused a lot of sandbuild up as she was mainly used on for leveling out a horse track.
      4) clean all the acid and remove all the old wiring to do a full rewiring
      5) replace the plastic seat pan with a metal.
      6)...
      I'm looking forward on my first C.
      It's also my first hydro, I don't know a lot about them and prefer actual gears. Simpler and need less maintenance (parts-shortage).
      But since I couldn't find another project WH and me hearing a lot of good things about hydro's  on the forum..  I finally took the shot.
    • Devin
      By Devin
      It runs and drives!
    • Devin
      By Devin
      Bought a C-175 a month ago Havent been able to get it running yet but when I do I would like to be able to use it I bought it without a deck and I want to know if there are any compatible decks or if I have to buy a original one because from what I have seen those are rare and expensive
    • shallowwatersailor
      By shallowwatersailor
      Most members probably recognize me for the 5xi tractors but I do have a few other Wheel Horse tractors, including my second favorite, the Blackhoods. I worked two of my three today.
      The C-145 came back from just sitting since I broke my ankle in June 2015. I was using it in the beginning of grass season while I prepped the 523Dxi ffor a trip to the Big Show. It never was stored properly but yesterday was a rainy day so I figured I would play around and see where I got to with it. Put a fresh battery in, it had spark, so I tried putting gas in it. Lets say gas flowed through the tank. It seems the mice were at this tractor, as well as my C-105, as gas came flowing out from around the valve. Called my local Wheel Horse (Toro) guy and he had two valves and grommets in stock. Using some new gas line I had, I re-ran the fresh line and added a fuel filter in-line while I was at it. Poured gas in the tank and second crank, it starts! Speaks well of Kohler K-series, Marvel Mystery Oil, and Stabil Marine additive. Not bad for sitting under my carport for 16 months unused! It needs a bath - really bad.
      After cutting the lawn, I needed to put down some Fall fertilizer. The DC-105 came out to do the honors with the spreader in tow. Its the perfect tractor as the torque available with the diesel never slows it down climbing my embankments. Plus it does have positive lubrication, unlike the K-Series, so I don't have to worry about starving it.
      A nice fun day for seat time!
    • cschannuth
      By cschannuth
      Does anyone know the reasoning behind the black hoods like my C-161 shown below?  I like it because it was my dad's and looks a bit sinister but from the hood to the headlight bezel to the twin Briggs, I just wonder why they built it. It's been a great machine. Dad bought it when it was a couple years old from a neighbor and it has had nothing done to it but regular maintenance, a little touch up to the paint, and a fresh set of decals. Even the tires are still in good shape with only a few cracks.
