marreque
Reunited after 25 years
ebinmaine
4 minutes ago, marreque said:
Can someone suggest where I can get a fuel pump rebuild kit?? I ordered from Amazon and it's a complete piece of crap!! Sent it back...
Call Then And Now Automotive. Weymouth Massachusetts I believe.
marreque
Not to far from me!!
ebinmaine
Even better!
marreque
Ok guys I need some help...... I rewired the 1054 today, following the wire diagram to a T, but now the tractor has power weather the key is on or off. Also installed new coil, condenser, gap the points, set the valves and new fuel line. Any help is appreciated and thanks in advance!!
Blasterdad
I would check the ignition switch, probably bad...
See if "off" is actually off...
marreque
I verified the switch is good with the ohm meter. Thank you
23 Reo
Please tell us about your tractor with the old Brigs and snow blower.
marreque
Sure, it's a Simplicity VC. Bought new by my grandfather with a snow blower, plow, and lawn mower.
oliver2-44
Using the wiring diagram following it with a test light or voltage meter. With the key off it will tell you where the power is coming from
953 nut
:text-yeahthat:
What generator indicating light socket did you use? Is the generator light connected to the battery side of the starter push button?
The Cloe Hersee PL 20 RC light has two wires that go to the light bulb and there is no reference to ground on the light bulb. If you are using the old stock light that came on the tractor be sure the wires are not touching each other or ground.
Picture 1 of 3
  • Like 4
marreque
There isn't a gen light in the dash, so I went right to the button with the wire.
marreque
Also, the wiring diagram shows the voltage regulator having constant power from the battery. Is that correct or should it be switched power?
marreque
Another question.....the steel fuel line from the pump to carburator, what do we use for the rubber gasket in between the fittings??
953 nut
Bought some from Zoro a few years back. May be able to find them other places on the internet too.
3/16" COMPRESSION VITON SLEEVE 10PK
PARKER| Zoro #: G2130703| Mfr #: 60VLV-3
0.0
No ReviewsWrite the First Review
Pipe and Fittings Size Guide
DETAILS:
Item: SleeVe
Temp. Range: -15 Degrees to 450 Degrees F
Tube Size: 3/16"
View Full Product Details
Orders over $50.00 ship FREE. DetailsStandard ground shipping
Limited Stock
Item ships from Zoro in 1 business day.
$7.36/PK
953 nut
That seems to be correct, the wiring for a 1055 also shows a wire from the battery + to the center terminal of the VR.
What wire are we talking about. If there is no generator light just eliminate that portion of the wiring, don't connect the key switch to the starter push button.
marreque
0.0
DETAILS:
Item: SleeVe
Tube Size: 3/16"
Limited Stock
$7.36/PK
Thank you
marreque
Ok guys, update time. Been playing with the 1054A and decided to hit the starter button after priming the carb with the fuel pump primer lever 50 times. I actually could not believe it as it fired right up!!!! I never touched the carburetor at all, it's how I parked it 25yrs ago.
  • Excellent 3
WHGuy413
It’s so awesome to see tractors come back into the family they started with or to the family that they really were enjoyed by. I officially finally have all of my grandfathers tractors (dads dad had a bronco 14 and a 1848, moms dad had a 416h) and my dads tractor (12 automatic). Look forward to seeing your progress.
  • Heart 1
marreque
Could someone please tell me how the original seat mounts to the backrest bar? The original seat was gone way before I can remember.
Pullstart
Congrats on the first fire in 25 years!  Woo hoo!
The seat will have inserts in it.  It bolts on from the back with 1/4-20 bolts.
marreque
My seat support is round with small pieces of tubing welded on almost like it would flip up to put gas in it.
Pullstart
I believe the bottom pad just sits there.  That’s the way all mine do.  Possibly the 1054A had the round tube and the 953/1054 had the bent square? Possibly yours has been remade?
marreque
I'll post a picture later today.
ebinmaine
@953 nutmight have that answer
marreque
