Heatingman 971 #51 Posted September 26, 2022 1 hour ago, davidfindlay said: Do you happen to know the specs for them (TPI or whatever)? I have the engine service manual but it's not searchable as it's old. Just take one of the originals with you to the hardware store. Share this post Link to post Share on other sites
davidfindlay 51 #52 Posted October 2, 2022 Tractor is up and running again. Thank you all for the advice! 1 4 Share this post Link to post Share on other sites
Jeff-C175 7,203 #53 Posted October 2, 2022 (edited) On 9/23/2022 at 4:58 PM, pacer said: the 2 at the exhaust came out painfully, and on reinstall both stripped, One I did last week I noticed that one of the head bolt holes at the exhaust port was actually drilled into the exhast port just a little bit. The bolts came out fine but I noticed the end of the bolt was covered in exhaust soot. Looking down the hole along one side you could look into the exhaust port. It's always a good idea to 'chase' the threads with a tap before reassembling. I posted this pic in a couple other threads recently, it illustrates why it's a good idea to pull the head every few years to clean the combustion chamber, flatten the head, and renew the gasket. This one was very close to blowing completely. This is from a K301. Note that the location of this is at the inside bend, same place as the other earlier pics showed gasket failure, right near the exhaust valve. Edited October 2, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
ebinmaine 70,788 #54 Posted October 2, 2022 35 minutes ago, davidfindlay said: Tractor is up and running again. Thank you all for the advice! Excellent!! 1 Share this post Link to post Share on other sites
