23 Reo 229 #1 Posted September 22, 2022 I have an older Tecumseh 10 hp that I would like to convert to electronic ignition. The engine number is HM 100 159 9120M SER 713SD. How would I do this and what specific parts would I need? Share this post Link to post Share on other sites
pfrederi 18,314 #2 Posted September 22, 2022 Do you mean the solid state ignition Techy used for several years or are you trying to replace that... Share this post Link to post Share on other sites
Achto 28,694 #3 Posted September 22, 2022 1 hour ago, 23 Reo said: I have an older Tecumseh 10 hp that I would like to convert to electronic ignition. If you have an engine with points and you are looking to eliminate the points. This will do the trick. It is an electronic pick up designed to replace the points. https://www.amazon.com/ROP-Shop-Universal-Electronic-TRANSISTORIZED/dp/B06XK26H45/ref=asc_df_B06XK26H45/?tag=hyprod-20&linkCode=df0&hvadid=198076851563&hvpos=&hvnetw=g&hvrand=553492647973114816&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028137&hvtargid=pla-349692599022&psc=1 2 Share this post Link to post Share on other sites
ebinmaine 70,609 #4 Posted September 22, 2022 @Snoopy11 Just added electric ignition to his tech 12 @Ed Stoller isn't on Redsquare very often but he's been working on perfecting a kit for many years. I have one of his kits here that I'll likely be using on one of my OHV160 engines. 2 Share this post Link to post Share on other sites
23 Reo 229 #5 Posted September 22, 2022 I am trying to get rid of the points. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,609 #6 Posted September 22, 2022 6 minutes ago, 23 Reo said: I am trying to get rid of the points. If you're trying to get rid of the points all together I would highly recommend calling Ed. I have his contact information here. If you send me a PM I'll get it to you. Another possible option would be to leave the points in there or install a new set but change over to the small module that is sold for the pulling engine crowd. I can't remember the name of it but it might come to me eventually. It replaces your condenser and it takes almost all the amperage away from the points. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,235 #7 Posted September 22, 2022 http://overnight-solutions.com/Index_Files/TSSS System Information.html 1 Share this post Link to post Share on other sites
ineedanother 1,377 #8 Posted September 23, 2022 7 hours ago, Achto said: If you have an engine with points and you are looking to eliminate the points. This will do the trick. It is an electronic pick up designed to replace the points. https://www.amazon.com/ROP-Shop-Universal-Electronic-TRANSISTORIZED/dp/B06XK26H45/ref=asc_df_B06XK26H45/?tag=hyprod-20&linkCode=df0&hvadid=198076851563&hvpos=&hvnetw=g&hvrand=553492647973114816&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028137&hvtargid=pla-349692599022&psc=1 I've used these with good success on chainsaws but also had to change the flywheels to account for about a 10* difference in timing. 1 Share this post Link to post Share on other sites
Heatingman 971 #9 Posted September 24, 2022 On 9/22/2022 at 1:29 PM, ebinmaine said: @Snoopy11 Just added electric ignition to his tech 12 @Ed Stoller isn't on Redsquare very often but he's been working on perfecting a kit for many years. I have one of his kits here that I'll likely be using on one of my OHV160 engines. Think this is the thread. Fairly inexpensive fix. https://www.wheelhorseforum.com/topic/99664-tecumseh-hh120-120045c-restoration/ 1 Share this post Link to post Share on other sites
Ed Stoller 19 #10 Posted September 25, 2022 From other emails, the Tecumseh HM100 has a capacitance discharge ignition but it is not a 610748, 610855, 610759, or a 610906. For reference see www.enginesandmagnets.com and the following: New Replacement Ignition, General Information General GM LS2 General.mp4 https://youtu.be/0p35PJwJ04o Trigger Pins GM LS2 Trigger Pins.mp4 , https://youtu.be/eMvB0-DIFEo Magneto Used for a Trigger.mp4 https://youtu.be/2kGMbUZ90iE Installations Kohler 161 Installation GM LS2 PC2short1.mp4 https://youtu.be/-2jHuThQHz4 GM LS2 PC2shortP2.mp4 https://youtu.be/XvkX2KbZClg Tecumseh HH120 Installation, Tecumseh.mp4 https://youtu.be/WsMY5D-q6pQ ONAN NB Installation https://www.youtube.com/watch?v=b5CXlirfTqc Kohler Command Ignition https://youtu.be/zXz-Q1z7A-s Miller Tecumseh Ignition Repair.mp4 https://youtu.be/bCEzLarsAuY Miller 2E Tecumseh OHV Issues.mp4 https://youtu.be/KVPcdZxuCHw Miller2E Tecumseh Ignition P1 https://youtu.be/5i7vUtx7J24 Miller2E Tecumseh Ignition P2 https://youtu.be/I6rWXaSyf6s Fly Trap Ed Stoller 1 Share this post Link to post Share on other sites
ebinmaine 70,609 #11 Posted September 26, 2022 20 hours ago, Ed Stoller said: reference Thanks for chiming in Ed. I was hoping you'd see a notice. Share this post Link to post Share on other sites
