John2189 503 #1 Posted September 15, 2022 Once in awhile it seems to just run on one cylinder for about 20-30 seconds then runs normal. I’ve pulled the choke when it happens and it doesn’t change, so I don’t think it is fuel related. when a coil goes bad, can it be erratic, or go bad right away. or mabe a bad spark plug? Share this post Link to post Share on other sites
8ntruck 7,383 #2 Posted September 15, 2022 Sounds like an ignition problem to me. Fouled spark plug? Bad coil? Bad spark plug wire? 1 Share this post Link to post Share on other sites
RED-Z06 2,479 #3 Posted September 15, 2022 Try new RC12YC plugs first, if it continues, may have to dig deeper into the ignition. Do you see a black box on the cowling, little smaller than a deck of cards? Share this post Link to post Share on other sites
John2189 503 #4 Posted September 15, 2022 6 hours ago, RED-Z06 said: Try new RC12YC plugs first, if it continues, may have to dig deeper into the ignition. Do you see a black box on the cowling, little smaller than a deck of cards? The plugs are new, don’t remember the number of them. But that doesn’t mean one could be bad. It has the black plastic impulse fuel pump and the voltage regulator Share this post Link to post Share on other sites
John2189 503 #5 Posted September 15, 2022 22 minutes ago, John2189 said: The plugs are new, don’t remember the number of them. But that doesn’t mean one could be bad. It has the black plastic impulse fuel pump and the voltage regulator Could the fuel pump be going bad? Earlier this summer, I replaced all the rubber hoses because they were hard. Share this post Link to post Share on other sites
RED-Z06 2,479 #6 Posted September 15, 2022 1 hour ago, John2189 said: The plugs are new, don’t remember the number of them. But that doesn’t mean one could be bad. It has the black plastic impulse fuel pump and the voltage regulator So you dont see a module like this? Share this post Link to post Share on other sites
John2189 503 #7 Posted September 15, 2022 22 minutes ago, RED-Z06 said: So you dont see a module like this? No nothing like that. This is a Simplicity, not a Wheel Horse. Share this post Link to post Share on other sites
RED-Z06 2,479 #8 Posted September 16, 2022 12 hours ago, John2189 said: No nothing like that. This is a Simplicity, not a Wheel Horse. Its a Kohler Command...All Kohler Command Twins and Singles fot about a decade, used a SAM module that retarded timing for easier starting and ramped timing in as speed increased for more power. When the SAM modules fail they cause timing to jump around and in some cases, because the coils were independently controlled, cause intermittent loss of spark...the fix was to replace the coils with the updated solid state coils and harness. Here is the module on my 27hp Command on my Simplicity Share this post Link to post Share on other sites
John2189 503 #9 Posted September 16, 2022 (edited) 1 hour ago, RED-Z06 said: Its a Kohler Command...All Kohler Command Twins and Singles fot about a decade, used a SAM module that retarded timing for easier starting and ramped timing in as speed increased for more power. When the SAM modules fail they cause timing to jump around and in some cases, because the coils were independently controlled, cause intermittent loss of spark...the fix was to replace the coils with the updated solid state coils and harness. Here is the module on my 27hp Command on my Simplicity Mine doesn’t have that box. Its a 1996 Sunstar. The book says it has an electronic CD ignition system the model number for the motor is ch20 Edited September 16, 2022 by John2189 Share this post Link to post Share on other sites
John2189 503 #10 Posted September 16, 2022 Put new plugs in and it still did it. Im guessing coils are next. I hate it when there is an intermittent problem. Id rather it go completely bad to make it easier to find Share this post Link to post Share on other sites
RED-Z06 2,479 #11 Posted September 17, 2022 On 9/16/2022 at 1:00 PM, John2189 said: Put new plugs in and it still did it. Im guessing coils are next. I hate it when there is an intermittent problem. Id rather it go completely bad to make it easier to find You can try to close the plug gaps some...this can mask a failing coil...if it stops then you know Share this post Link to post Share on other sites
John2189 503 #12 Posted September 17, 2022 16 minutes ago, RED-Z06 said: You can try to close the plug gaps some...this can mask a failing coil...if it stops then you know The plugs I took out only has 6 -10 hours on them and they look like new Share this post Link to post Share on other sites
RED-Z06 2,479 #13 Posted September 18, 2022 14 hours ago, John2189 said: The plugs I took out only has 6 -10 hours on them and they look like new Cool. That has nothing to do with what i posted. Closing the gap makes it easier to jump the gap, if the problem improves then you can safely say its a bad coil Share this post Link to post Share on other sites
John2189 503 #14 Posted September 18, 2022 59 minutes ago, RED-Z06 said: Cool. That has nothing to do with what i posted. Closing the gap makes it easier to jump the gap, if the problem improves then you can safely say its a bad coil Ok I just re read your post. Im at the beach right now. I’ll close the gap when I get home. Share this post Link to post Share on other sites
RED-Z06 2,479 #15 Posted September 18, 2022 2 hours ago, John2189 said: Ok I just re read your post. Im at the beach right now. I’ll close the gap when I get home. I had a briggs twin that would drop a lung under heavy load, perfect compression, new carb, no leaks...started fine and idled fine...turn on the deck and it would drop one side until it got back to full speed. I closed the gaps to .020 from .030 and while that did cost me some power...it no longer dropped a cylinder. New coils fixed it Share this post Link to post Share on other sites
John2189 503 #16 Posted September 18, 2022 Thanks I’ll try it. The bad thing is I just had everything apart to put new head gaskets never thought ro look to see what it had for the ignition Share this post Link to post Share on other sites
Wild Bill 633 866 #17 Posted September 23, 2022 On 9/15/2022 at 8:16 AM, John2189 said: This is a Simplicity, not a Wheel Horse. FYI, simpletractors.com is the Simplicity & Allis Chalmers website. The older Kohler Command ignition coils are known to go bad. The CH20-64512 replacement ignition coil is P/N 24 584 201-S, $54.78 each. 0.012" clearance gap. Share this post Link to post Share on other sites
John2189 503 #18 Posted September 23, 2022 (edited) 5 hours ago, Wild Bill 633 said: FYI, simpletractors.com is the Simplicity & Allis Chalmers website. The older Kohler Command ignition coils are known to go bad. The CH20-64512 replacement ignition coil is P/N 24 584 201-S, $54.78 each. 0.012" clearance gap. Thanks I’ve not heard of them, I’ll join that forum Edited September 23, 2022 by John2189 Share this post Link to post Share on other sites
John2189 503 #19 Posted September 26, 2022 On 9/18/2022 at 1:29 PM, RED-Z06 said: I had a briggs twin that would drop a lung under heavy load, perfect compression, new carb, no leaks...started fine and idled fine...turn on the deck and it would drop one side until it got back to full speed. I closed the gaps to .020 from .030 and while that did cost me some power...it no longer dropped a cylinder. New coils fixed it I closed the gap for the plugs from.030” to.020”. That didn’t help it. Still does it and it takes it longer to recover. I have new coils on order. john 1 Share this post Link to post Share on other sites
