Electrical
Section Instructions
We have provided this section to consolidate instructional posts which are found within the various RedSquare forums.  You may not begin a new instructional thread here, but request that is move to this section.
To nominate a thread, please utilize the "Report Post" link at the top of the first post and include in the comments that this thread should be moved  to this section.  Your nomination will be considered and if accepted, the thread will be moved.  You will not be contacted with the decision either way.
20 topics in this forum
    • 43 replies
    • 116,721 views
    • 5 replies
    • 4,631 views
  1. Indicator Lites 1 2 3 4
    • 79 replies
    • 38,889 views
  2. wiring diagram for a wheelhorse R26
    • 2 replies
    • 1,390 views
  3. 3 pronged ignition switch
    • 21 replies
    • 11,627 views
  4. Using the wrong ignition switch
    • 3 replies
    • 4,781 views
  5. How To - Measure RPM's with a Multimeter
    • 11 replies
    • 108,841 views
  6. Onan Ignition Module testing - off the engine 1 2 3 4
    • 99 replies
    • 72,707 views
    • 17 replies
    • 8,825 views
  7. Charging system problems 520H
    • 20 replies
    • 13,273 views
  8. How To - Test a Diode
    • 2 replies
    • 6,627 views
  9. Electric fuel pump revisited
    • 13 replies
    • 7,661 views
  10. Locating Parasitic Battery Drain 1 2
    • 42 replies
    • 13,482 views
  11. 416 PTO safety switch help..
    • 6 replies
    • 5,957 views
  12. Ignition Question
    • 22 replies
    • 6,860 views
  13. Wiring question for my 702
    • 17 replies
    • 5,282 views
  14. Bright headlights 1 2
    • 38 replies
    • 13,945 views
  15. c175
    • 1 reply
    • 4,350 views
  16. Bright Lights for your C-series
    • 7 replies
    • 4,404 views
  17. charging problem
    • 11 replies
    • 5,077 views
