Engines
Section Instructions
We have provided this section to consolidate instructional posts which are found within the various RedSquare forums.  You may not begin a new instructional thread here, but request that is move to this section.
To nominate a thread, please utilize the "Report Post" link at the top of the first post and include in the comments that this thread should be moved  to this section.  Your nomination will be considered and if accepted, the thread will be moved.  You will not be contacted with the decision either way.
83 topics in this forum
    • 43 replies
    • 35,712 views
  1. Why I am not big fan of electric PTOs 1 2 3
    • 54 replies
    • 23,948 views
  2. pictures of k241 starter teardown 1 2 3 4
    • 83 replies
    • 29,393 views
    • 2 replies
    • 3,577 views
  3. Balancing Gears - in or out 1 2 3
    • 62 replies
    • 24,655 views
  4. pto chirp
    • 15 replies
    • 7,544 views
    • 24 replies
    • 10,317 views
    • 15 replies
    • 16,000 views
  5. Installing Head Gaskets
    • 21 replies
    • 9,977 views
  6. Pulling Engines, What Do You Use? 1 2
    • 38 replies
    • 12,049 views
  7. Kohler small block rebuild tutorial 1 2 3
    • 57 replies
    • 31,510 views
  8. PTO Bearings Replace Pictorial
    • 4 replies
    • 5,249 views
  9. Speed up Your Horse 1 2 3 4
    • 84 replies
    • 53,334 views
    • 9 replies
    • 6,274 views
  10. 701 VS 702 starter pulleys
    • 1 reply
    • 4,076 views
  11. 6hp tecumseh Blowbye
    • 17 replies
    • 10,191 views
  12. 520 Onan Oil Filter Number ? 1 2
    • 35 replies
    • 50,096 views
  13. ID, Repair and Adj Kohler Carburators
    • 6 replies
    • 9,722 views
  14. How To - Renew Cylinder Head Gasket Sealing Surface
    • 16 replies
    • 14,050 views
  15. Napa Has Small Engine Parts
    • 22 replies
    • 14,283 views
  16. leak down tester
    • 5 replies
    • 7,611 views
  17. Freeing up Throttle & Choke cables
    • 19 replies
    • 15,549 views
  18. Onan Oil Filter - Looking for part number
    • 7 replies
    • 6,345 views
  19. PTO Needle Bearing Replacement
    • 20 replies
    • 13,947 views
  20. K91 oil bath air filter problems
    • 3 replies
    • 4,647 views
