Tractor 1967 867 D&A OM IPL Wiring Rev SN.pdf
6 Screenshots
Operator manual #348
15 pages 2.17MB
Dated 1/1/67
1 page 326KB
Models 867, 1067 and 1267 first models to get headlamps as standard equipment
Tractor drive belt for 867 #9691 - 1/2" x 70"
Big Block Kohler Napa # 25-7345   .41" wide x 35.3" long side angle 37 degrees Cross section HC41
Includes PSB #252 for converting limited slip differential to 8-pinion
3 pages 115.41KB
1967 model 867 - Short frame model
1967 serial numbers that have shown up for the 867
364882
364883
367714
367748
367781
367945
370193
370432
374038
374051
377866
377965
378305
378506
381200
