Tractor 1967 857 D&A OM IPL Wiring Rev SN.pdf
6 Screenshots
Operator manual #A-5090
12 pages 2.01MB
1 page 296KB
Tractor drive belt for 857 #9691 - 1/2" x 70"
Gates 6870
Napa 4L700W
Original ignition switch 4988 replaced by 7263
No decal on belt guard. Indentation was dropped on 4993 guard in 1967
Last line of the parts list is missing
Item 139 - 920127-4 Lockwasher 9/16
Item 186 - 6998 Decal Grille
3 pages 114.91KB
1967 model 857
1967 serial numbers that have shown up for the 857
266108
266307
266388
266526
266622
266896
266949
284035
284158
290859
290869
29116x
291215
306554
306723
306820
307114
307220
307426
307477
325035
325050
325396
325402
333992
336561 - Located in UK
336677
336700
336833
336998
372790
372875
