Transmission Uni-Drive Axle
Transmission Uni-Drive Axles
First edition - March 7, 2020 - 13 pages 290KB
Revision 1 - March 17, 2020 - 13 pages 290KB
Will be revised when mistakes are corrected and new info appears
ipl = original illustrated parts list
Tipl = illustrated parts list from Toro Master Parts Viewer may not be accurate
1-1/8" axles used in Uni-Drive transmissions
3-Speed transmission models - 5045 (1963), 5047 (1964), 5051 (1965), 5058 (1967), 5059 (1966),
3-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section II of the service manual.
6-Speed transmission models - 5060 (1967-1968), 5071 (1969),
6-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section III of the service manual.
8-Speed transmission models - 5073 (1970-1973) , 5091 (1973-1976),
103907 (1976-1977), 103916 (1978-1984), 103918 (1980-1983), 110995 (1985-1993),
92-8707 (1993-2001), 92-8708 (1994-2005 and 2007)
?????? x 1-1/8" diameter 121384 replaces 6450, 6451, 7202, 7203, 101510 and 101511 - (Also used in hydro models) - My guess this one is 12" long. No reason why a longer axle couldn't replace a shorter one.
The 7202 and 7203 were last used in 1973 so the 101510 and/or 101511 may have been service replacements and the 121384 replaced these two.
?????? x 1-1/8" diameter 2825 left axle (1963-1965) - No longer available - Left axle
?????? x 1-1/8" diameter 2824 right axle (1963-1965) - No longer available - Right axle
11-1/8" x 1-1/8" diameter 6451 (1967) replaced by 121384 left axle - 6451 no longer available - (Also used in hydro models 1966-1968)
11-1/4" x 1-1/8" diameter 7203 left axle (1967-1973) replaced by 121384 - 7203 no longer available - (Also used in hydro models 1968-1973)
11-1/4" x 1-1/8" diameter 101511 replaced by 121384 - Unknown application
11-5/8" x 1-1/8" diameter 102764 (1973-1976) replaced by 99-5359 kit left and right axles - 99-5359 still available March 10, 2020 $246.71 - (Also used in hydro models 1973-1976)
11-3/4" x 1-1/8" diameter 6450 (1967) replaced by 121384 right axle - (Also used in hydro models 1966-1968)
12" x 1-1/8" diameter 7202 (1967-1973) replaced by 121384 right axle - (Also used in hydro models 1968-1973)
12" x 1-1/8" diameter 101510 replaced by 121384 - Unknown application - Length is a guess since the 101511 is 11-1/4" long
13-1/8" x 1-1/8" diameter 105875 left and right axle (1976-2007) - 105875 still available March 10, 2020 $237.66 - (Also used in hydro models 1973-1981)
121384 axle replaces 6450, 6451, 7202, 7203, 101510 and 101511 axles - 121384 no longer available
Applications
1963 model 953 - 5045 - Left axle 2825 Right axle 2824 - (Axle seal 1213 1-1/8" ID) - 2 bevel pinions - Ipl # 123
1964 model 1054 - 5047 - Left axle 2825 Right axle 2824 - (Axle seal 1213 1-1/8" ID) - 2 bevel pinions - Ipl # 177
1965 model 1054A - 5051 - Left axle 2825 Right axle 2824 - (Axle seal 1213 1-1/8" ID) - 2 bevel pinions - Ipl # 177-A
1966 service replacement - 5059 - replaced 5045, 5047 and 5051 for the 953, 1054 and 1054A
1967 model 867 - 5060 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 1213 1-1/8" ID) - 10 pinion limited slip - Ipl # 348
1967 model 1057 - 5058 - Left axle 6451 11-1/8", Right axle 6450 11-3/4" - Both replaced by 121384 nla- (Axle seal 1213 1-1/8" ID) - 2 bevel pinions - Ipl # 310 - OM IPL lists a 5080 (typo) model transmission and shows bevel pinion gears.
1967 model 1067- 5060 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 1213 1-1/8" ID) - 10 pinion limited slip - Ipl # 346-347
1967 model 1257- 5058 - Left axle 6451 11-1/8", Right axle 6450 11-3/4" - Both replaced by 121384 nla - (Axle seal 1213 1-1/8" ID) - 2 bevel pinions - Ipl # 310 - OM IPL lists a 5080 (typo) model transmission and shows bevel pinion gears.
1967 model 1267- 5060 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 1213 1-1/8" ID) - 10 pinion limited slip - Ipl # 346-347
1968 Raider 9 model 1-6931 - 5060 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 1213 1-1/8" ID) - 10 pinion limited slip - Ipl # 359
1968 Raider 12 model 1-6231 - 5060 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 1213 1-1/8" ID) - 10 pinion limited slip - Ipl # 357
1969 Raider 10 model 1-6041 - 5071 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 1213 1-1/8" ID) - 10 pinion limited slip - Ipl # 1-6041-P
1969 Raider 12 model 1-6241 - 5071 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 1213 1-1/8" ID) - 10 pinion limited slip
1970 Raider 10 model 1-6051 - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinion limited slip - Ipl # A-5203
1970 Raider 12 model 1-6251 - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinion limited slip - Ipl # A-5203
1970 Raider 12 model 1-6252 - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinion limited slip
1970 Raider 12 model 1-6253 - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinion limited slip - Ipl # A-5203
1971 Raider 10 model 1-0300 - (1-0300-6) - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinion limited slip - 10R in ipl # A-5279 - 10hp Lauson
1971 Raider 12 model 1-0310 - (1-0310-6) - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinion limited slip - 12R in ipl # A-5279 - 12hp Kohler
1972 Raider 12 model 1-0311 - (1-0311-7) - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinion limited slip - Ipl # A-5309
1972 Raider 14 model 1-0320 - (1-0320-7) - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinion limited slip - Ipl # A-5309
1973 8hp 4-speed model 1-0274 - (1-0274-8) - Vertical shaft Not listed at Toro. It is listed in the WH belt charts
1973 8hp 4-Speed model 1-0276 - (1-0276-8) - Vertical shaft
1973 8hp 4-Speed model 1-0277 - (1-0277-8) - Vertical shaft
1973 12hp 8-Speed model 1-0350 - (1-0350-8) - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinions - Ipl # A-5347
1973 12hp 8-Speed model 1-0353 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) - Listed in PSB #301E for 1973-74. Suspect 1973 is wrong - Has shown up made in Belgium as a Raider 12
1973 12hp 8-Speed model 1-0354 - Listed in PSB #301E for 1973-74. Suspect 1973 is wrong - Has shown up also made in Belgium
1973 12hp 8-Speed model 1-0355 - (1-0355-8) - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1973 14hp 8-Speed model 1-0340 - (1-0340-8) - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinions - Ipl # A-5347
1973 Raider 12 8-Speed model 1-0350 - 5073 - Left axle 7203 11-1/4", Right axle 7202 12" - (Axle seal 100443 1-1/8" ID) - 10 pinions - Ipl # A-5347 - Made in Belgium
1973 Raider 12 8-Speed model 1-0355 - (1-0355-8) - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1974 C-100 8-Speed model 1-0390 - (1-0390-9) - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1974 C-120 8-Speed model 1-0353 - (1-0353-9) - 5091 - Also made in Belgium - Serial 997047 is US production
1974 C-120 8-Speed model 1-0354 - (1-0354-9) - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1974 C-120 8-Speed model 1-0356 - (1-0356-9) - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1974 C-160 8-Speed model 1-0380 - (1-0380-9) - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1974 C-160 8-Speed model 1-0385 - (1-0385-9) - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1974 Raider 10 8-Speed model 1-0390 - (1-0390-9) - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) - Made in Belgium
1974 Raider 12 8-speed model 1-0353 - (1-0353-9) - 5091 - 2 x 102764 axles - (Axle seal 100443 1-1/8" ID) - Made in Belgium
1974 Raider 14 8-speed model 1-0380 - (1-0380-9) - 5091 - 2 x 102764 axles - (Axle seal 100443 1-1/8" ID) - Made in Belgium - (C-160 8-Speed in USA)
1975 B-145 Elec-Trak model 1-0720 - Uses Peerless 2318
1975 C-100 8-Speed model 1-0391 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803983 - (Also made in Belgium)
1975 C-120 8-Speed model 1-0357 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1975 C-120 8-Speed model 1-0375 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) - Decaled C-120 Special
1975 C-120 8-Speed model 1-0395 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803983
1975 C-120 8-Speed model 1-0396 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1975 C-160 8-Speed model 1-0381 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803983
1975 C-185 Elec-Trak model 1-0700 - - Uses Peerless 2318
1975 Raider 12 8-Speed model 1-0357 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) - Made in Belgium
1975 Raider 12 8-Speed model 1-0375 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) - Made in Belgium
1976 B-60 8-Speed model 61-07K801 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 B-60 8-Speed model 61-07K802 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 B-80 8-Speed model 61-08K801 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) Incorrectly named a B-60 @ Toro -
1976 B-80 8-Speed model 61-08K802 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) Incorrectly named a B-60 @ Toro -
1976 B-80 8-Speed model 61-08K803 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1976 B-80 8-Speed model 61-08K804 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID) Incorrectly named a B-60 @ Toro -
1976 B-100 8-Speed model 61-10K801 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 B-100 8-Speed model 61-10K802 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 B-100 8-Speed model 61-10K803 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1976 B-100 8-Speed model 61-10K804 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 B-145 Elec-Trak model 1-0720 - Uses Peerless 2318
1976 C-120 8-Speed model 61-12K801 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 C-120 8-Speed model 61-12K802 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 C-120 8-Speed model 61-12K803 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1976 C-120 8-Speed model 61-12K804 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 C-140 8-Speed model 61-14K8 - Made in Belgium
1976 C-160 8-Speed model 61-16K801 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 C-160 8-Speed model 61-16K802 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 C-160 8-Speed model 61-16K803 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1976 C-160 8-Speed model 61-16K804 - 5091 - 2 x 102764 11-5/8" axles - (Axle seal 100443 1-1/8" ID)
1976 C-185 Elec-Trak model 1-0700 - Uses Peerless 2318
1977 B-60 8-Speed model 71-07K801 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803699
1977 B-80 8-Speed model 71-08K801 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803699
1977 B-100 8-Speed model 71-10K801 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803699 - (Also made in Belgium)
1977 B-145 Elec-Trak model 1-0720 - Uses Peerless 2318
1977 C-100 8-Speed model 71-10K8 - Assuming - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) (Made in Belgium)
1977 C-120 8-Speed model 71-12K801 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803699
1977 C-140 8-Speed model 71-14K8 - Assuming - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) (Made in Belgium)
1977 C-160 8-Speed model 71-16K801 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1977 C-160 8-Speed model 71-16K802 - 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803699
1977 C-185 Elec-Trak model 1-0700 - Uses Peerless 2318
1977 Raider 10 model 71-10K801- 103907 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 8 pinions - Ipl # 803699 - Made in Belgium
1978 C-81 8-Speed model 81-08K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1978 C-101 8-Speed model 81-10K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1978 C-121 8-Speed model 81-12K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) (Also made in Belgium)
1978 C-141 8-Speed model 81-14K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) (Also made in Belgium)
1978 C-161 8-Speed model 81-16K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1978 C-161 Twin 8-Speed model 81-16B801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1978 E-141 8-Speed model 01-14E801 - 103918 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) PSB #226 lists the E-141 as being a 1978 model. 1980-83 at Toro.
1979 C-81 8-Speed model 91-08K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1979 C-81 8-Speed model 91-08K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - ipl #810118R1
1979 C-81 8-Speed model 91-08K891 (Made in Belgium)
1979 C-101 8-Speed model 91-10K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1979 C-101 8-Speed model 91-10K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - ipl #810118R1
1979 C-101 8-Speed model 91-10K892 (Made in Belgium)
1979 C-111 8-Speed model 91-11B801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - ipl #810118R1
1979 C-121 8-Speed model 91-12K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1979 C-121 8-Speed model 91-12K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - ipl #810118R1
1979 C-121 8-Speed model 91-12K891 (Made in Belgium)
1979 C-121 8-Speed model 91-12K892 (Made in Belgium)
1979 C-141 8-Speed model 91-14K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1979 C-141 8-Speed model 91-14K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - ipl #810118R1
1979 C-161 8-Speed model 91-16K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - ipl #810118R1 - (5086 using 1" axles at Toro)
1979 C-161 Twin 8-Speed model 91-16B801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - Tipl - (5086 using 1" axles at Toro)
1979 C-161 Twin 8-Speed model 91-16B802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - ipl #810118R1 - (5086 using 1" axles at Toro)
1979 E-141 8-Speed model 01-14E801 - 103918 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) PSB #226 lists the E-141 as being a 1978 model. - 1980-83 at Toro.
1980 C-85 8-Speed model 01-08K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) Incorrectly named a C-81 @ Toro
1980 C-85 8-Speed model 01-08K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1980 C-105 8-Speed model 01-10K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1980 C-125 8-Speed model 01-12K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1980 C-145 8-Speed model 01-14K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1980 C-145 8-Speed model 01-14K891 (Made in Belgium)
1980 C-165 8-Speed model 01-16K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1980 C-175 Twin 8-Speed model 01-17K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1980 E-141 8-Speed model 01-14E801 - 103918 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) PSB #226 lists the E-141 as being a 1978 model. 1980-83 at Toro.
1981 C-85 8-Speed model 01-08K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) Incorrectly named a C-81 @ Toro
1981 C-105 8-Speed model 01-10K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1981 C-125 8-Speed model 01-12K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1981 C-145 8-Speed model 01-14K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1981 C-165 8-Speed model 01-16K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1981 C-175 Twin 8-Speed model 01-17K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1981 E-141 8-Speed model 01-14E801 - 103918 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) PSB #226 lists the E-141 as being a 1978 model. 1980-83 at Toro.
1982 C-85 8-Speed model 01-08K803 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1982 C-105 8-Speed model 01-10K803 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1982 C-125 8-Speed model 01-12K803 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1982 C-175 Twin 8-Speed model 01-17K803 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1982 E-141 8-Speed model 01-14E801 - 103918 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) PSB #226 lists the E-141 as being a 1978 model. 1980-83 at Toro.
1983 C- 85 8-Speed model 11-08K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1983 C-105 8-Speed model 11-10K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1983 C-125 8-Speed model 11-12K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1983 C-175 Twin 8-Speed model 11-17K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)
1983 E-141 8-Speed model 01-14E801 - 103918 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) PSB #226 lists the E-141 as being a 1978 model. 1980-83 at Toro.
1984 C-105 8-speed model 11-10K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID)- Some use alternate differential carrier bearings See PSB #369
1984 C-125 8-speed model 11-12K802 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - Some use alternate differential carrier bearings See PSB #369
1984 C-165 8-speed model 11-16K801 - 103916 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - Some use alternate differential carrier bearings See PSB #369
1985 416-8 model 31-16K801 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) 1-1/2" carrier brg (1-1/2x2-1/2x1/2in.)
1985 417-8 model 31-17K801 - 110955 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) 1-1/2" carrier brg (1-1/2x2-1/2x1/2in.)
1986 414-8 model 31-14K801 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 40mm carrier brg
1986 416-8 model 31-16K802 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 40mm carrier brg
1986 417-8 model 31-17K802 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 40mm carrier brg
1987 414-8 model 31-14K802 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 40mm carrier brg
1987 416-8 model 31-16K803 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 40mm carrier brg
1987 418-8 model 31-18K801 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 100443 1-1/8" ID) - 40mm carrier brg
1988 414-8 model 31-14K803 - 110995 - 2 x 2 x 105875 13-1/8" axles - ([Axle seal 2 x 100443 1-1/8" ID x 1-3/8" OD] or [2 x 6449 1-1/8" ID x 1-5/8" OD]) - 40mm carrier brg - Tipl
1988 416-8 model 31-16K804 - 110995 - 2 x 2 x 105875 13-1/8" axles - ([Axle seal 2 x 100443 1-1/8" ID x 1-3/8" OD] or [2 x 6449 1-1/8" ID x 1-5/8" OD]) - 40mm carrier brg - Tipl
1989 414-8 model 31-14K804 - 110995 - 2 x 2 x 105875 13-1/8" axles - ([Axle seal 2 x 100443 1-1/8" ID x 1-3/8" OD] or [2 x 6449 1-1/8" ID x 1-5/8" OD]) - 40mm carrier brg - Tipl
1989 416-8 model 31-16O801 - 110995 - 2 x 2 x 105875 13-1/8" axles - ([Axle seal 2 x 100443 1-1/8" ID x 1-3/8" OD] or [2 x 6449 1-1/8" ID x 1-5/8" OD]) - 40mm carrier brg - Tipl
1990 312-8 model 31-12K801 listed at Toro. Wrong and should be 110995 with 1-1/8" axles and 8 pinions
1990 312-8 model 31-12K801 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - Tipl
1990 continued
1990 312-8e model R1-12K802 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - Exported model - ipl # 899004
1990 316-8e model R1-16O802 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - Exported model - ipl # 899004
1990 416-8 model 31-16O802 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - Tipl
1990 520-8 model 41-20O801 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions? - Tipl shows 4 pinions
1991 310-8 model 31-10K802 serial numbers 11752, 11753, 11754 and 11755 use 1-1/8" axles and 4 pinion gears - Source 1991 - ipl # 3314-853
1991 310-8 model 31-10K802 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3314-853
1991 312-8 model 31-12K802 Serial 1900001-1999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3314-853
1991 416-8 model 31-16O803 Serial 1900001-1999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg9 - ipl # 3314-853
1992 312-8 model 31-12K804 Serial 2900001-2999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3315-196
1992 312-8e model R1-12K804 Serial 2900001-2999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3315-247 - Exported
1992 316-8e model R1-16O804 Serial 2900001-2999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3315-325 - Exported
1992 416-8 model 31-16O804 Serial 2900001-2999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3315-196
Toro lists the following as using 92-8708 transmission with 8 pinions and double axle seals but the parts lists have 110995 with 8 pinions and a single axle seal.
1993 314-8 model 73400 Serial 3900001-3999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3316-139 - 92-8708 trans model at Toro
1993 416-8 model 73420 Serial 3900001-3999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3316-141A - 92-8708 trans model at Toro
1993 416-8e model 73440 Serial 3900001-3999999 - 110995 - 2 x 105875 13-1/8" axles - (Axle seal 2 x 100443 1-1/8" ID) - 40mm carrier brg - ipl # 3316-141A - 92-8708 trans model at Toro - Exported
1994 312-8 model 73362 Serial 4900001-4999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3316-405
1994 314-8 model 73400 Serial 4900001-4999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3316-920
1994 312-8e model 73380 Serial 4900001-4999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3316-897 - Exported
1994 416-8 model 73420 Serial 4900001-4999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3316-927
1994 416-8e model 73440 Serial 4900001-4999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3316-927 - Exported
1995 312-8 model 73362 Serial 5900001-5999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3316-405
1995 314-8 model 73400 Serial 5900001-5999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3316-920
1995 416-8 model 73420 Serial 5900001-5900614 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - Tipl
1995 416-8 model 73420 Serial 5900615-5999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3317-889
1995 416-8e model 73440 Serial 5900001-5900222 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3316-927 - Exported
1995 416-8e model 73440 Serial 5900223-5999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3317-889 - Exported
1996 312-8 model 73362 Serial 6900001-6999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3316-405
1996 312-8 model 73363 Serial 6900001-6999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3318-518 (Gold trim)
1996 314-8 model 73400 Serial 6900001-6999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3316-920
1996 314-8 model 73402 Serial 6900001-6999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3318-519 (Gold trim)
1996 416-8 model 73420 Serial 6900001-6999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3317-889
1996 416-8 model 73422 Serial 6900001-6999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3318-521 (Gold trim)
1996 416-8e model 73441 Serial 6900001-6999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3318-522 (Gold trim) - Exported
1997 312-8 model 73363 Serial 7900001-7999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3319-158
1997 314-8 model 73402 Serial 7900001-7999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3319-159
1997 416-8 model 73422 Serial 7900001-7999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3319-161
1997 416-8e model 73441 Serial 7900001-7999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) 40mm carrier brg - 8 pinions - ipl # 3319-162 - Exported
1998 312-8 model 73428 Serial 8900001-8999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3319-710
1998 314-8 model 73448 Serial 8900001-8999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3319-711
1999 312-8 model 73429 Serial 9900001-9999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3322-109
1999 314-8 model 73449 Serial 9900001-9999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3322-109
2000 312-8 model 73429 Serial 200000001-200999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3324-231
2000 314-8 model 73449 Serial 200000001-200999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3324-231
2001 312-8 model 73429 Serial 210000001-210999999 - 92-8707 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 4 pinions - ipl # 3324-710
2001 314-8 model 73449 Serial 210000001-210999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3324-710
2002 315-8 model 73450 Serial 220000001-220999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3326-314
2003 315-8 model 73450 Serial 230000001-230999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3328-744
2004 315-8 model 73450 Serial 240000001-240999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3328-744
2005 GT Classic model 73450 Serial 250000001-250999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3353-258
2007 GT Classic model 73450 Serial 270000001-270999999 - 92-8708 - 2 x 105875 13-1/8" axles - (Axle seal 4 x 100443 1-1/8" ID) - 40mm carrier brg - 8 pinions - ipl # 3353-258
