Seals 1.0.0
You will notice the Chicago Rawhide / SKF seal spec sheets show a WastWatcher seal. That seal may be easier to find as they have determined it is a part number that will replace many seals with the same dimensions except for width and have characteristics that meet or exceed the seal it replaces.
A link to the SKF interchange
http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
Toro / Wheel Horse part numbers are first on each line
Seal 47-8030 Use 703333 -- Replaced by Chicago Rawhide / SKF 6105
Seal 56-2820 replaces 56-3270 & 112604 Eaton 1100 input shaft
Seal 56-3130 may be -- replaced by Chicago Rawhide / SKF 7465 (Eaton part number ER92999 replaced by SKF / Chicago Rawhide 7465) [Eaton 1100 selector shaft seal]
Seal 56-3270 replaced by 56-2820 Eaton 1100 input shaft
Seal 83-2830 replaces 1234 -- Replaced by Chicago Rawhide / SKF 7627
Seal 83-2840 replaces 1257, 100573 -- Available only from Toro - This seal mounts over the axle tube - See photo at the top
Seal 93-9807 replaces 112822 -- May be Chicago Rawhide / SKF 12407
Seal 253-44 replaces 1117, 108357, 700413, 707984 -- Replaced by Chicago Rawhide / SKF 7443
Seal 1011 -- Replaced by Chicago Rawhide / SKF 9859
Seal 1117 replaced by 253-44 -- Replaced by Chicago Rawhide / SKF 7443
Seal 1213 replaced by 100443 -- Replaced by Chicago Rawhide / SKF 11050 or National 340835
Seal 1232 replaced by 100863, See 114677, 9240 -- Replaced by Chicago Rawhide / SKF 9815
Seal 1234 replaced by 83-2830 -- Replaced by Chicago Rawhide / SKF 7627 or National 471643
Seal 1257 replaced by 83-2840 -- Available only from Toro - This seal mounts over the axle tube - See photo at the top
Seal 1303 replaced by 100441 -- Replaced by Chicago Rawhide / SKF 7410
Seal 1447 replaced by 5959 -- Replaced by Chicago Rawhide / SKF 4911
Seal 1461 replaced by 100442 -- Replaced by Chicago Rawhide / SKF 6105
Seal 1482 replaced by 103118 -- Replaced by Chicago Rawhide / SKF 12330
Seal 3373 -- Replaced by Chicago Rawhide / SKF 10035 or National 204005
Seal 5958 replaced by 100607 -- Replaced by Chicago Rawhide / SKF 9878
Seal 5959 replaces 1447 -- Replaced by Chicago Rawhide / SKF 4911
Seal 6449 -- Replaced by Chicago Rawhide / SKF 11124  (Original 6449 is 1/2" wide)
Seal 6663 -- Replaced by Chicago Rawhide / SKF 14810
Seal 7877 -- Replaced by Chicago Rawhide / SKF 7475 (Federal Mogul 480821 = CR 7474 , Original seal 9008000-7501 = CR 7443)
Seal 7963 -- Replaced by Chicago Rawhide / SKF 6904
Seal 9230 replaced by 703333 -- Replaced by Chicago Rawhide / SKF 6105
Seal 9240 May be same as 1232, 100863 and 114677 -- Replaced by Chicago Rawhide / SKF 9815 a guess. Used on tiller with 5571 bushing
Seal 100441 replaces 1303 -- Replaced by Chicago Rawhide / SKF 7410
Seal 100442 replaces 1461 -- Replaced by Chicago Rawhide / SKF 6105 (CR 11050 to replace 100442 @ SKF is wrong)
Seal 100443 replaces 1213 -- Replaced by Chicago Rawhide / SKF 11050 or National 340835
Seal 100573 replaced by 83-2840 -- Available only from Toro - This seal mounts over the axle tube - See photo at the top
Seal 100607 replaces 5958 -- Replaced by Chicago Rawhide / SKF 9878
Seal 100608 -- Replaced by Chicago Rawhide / SKF 6904
Seal 100863 Replaces 1232, 114677, 9240 -- Replaced by Chicago Rawhide / SKF 9815 a guess.
Seal 103103 -- Replaced by Chicago Rawhide / SKF 8620
Seal 103118 replaces 1482 -- Replaced by Chicago Rawhide / SKF 12330
Seal 103269 or 103277  -- Replaced by Chicago Rawhide / SKF 10740 (National 471762 seal for 5-0900 deck thinner than originals)
Seal 103461 -- Replaced by Chicago Rawhide / SKF 6763
Seal 106075 -- Replaced by Chicago Rawhide / SKF 9907 (Mower spindle original had double-lip)
Seal 108357 replaced by 253-44 -- Replaced by Chicago Rawhide / SKF 7443
Seal 112604 replaced by 56-2820 Eaton 1100 input shaft
Seal 112658 may be -- replaced by Chicago Rawhide / SKF 7465 (Eaton part number ER92999 replaced by SKF / Chicago Rawhide 7465) [Eaton 1100 selector shaft seal]
Seal 112822 replaced by 93-9807 -- May be Chicago Rawhide / SKF 12407
Seal 114677 replaced by 100863 -- Replaced by Chicago Rawhide / SKF 9815 a guess.
Seal 700413 replaced by 253-44 -- Replaced by Chicago Rawhide / SKF 7443
Seal 703333 replaces 9230 & 47-8030 -- Replaced by Chicago Rawhide / SKF 6105
Seal 707984 replaced by 253-44 -- Replaced by Chicago Rawhide / SKF 7443
Seal MW10390 -- Replaced by Chicago Rawhide / SKF 9878 Motorwheel? Used in snowthrower auger drive
Seal MW10459 - 3/4" shaft Used in snowthrower auger drive
  • Like 3
  • Heart 1
