Taken from #492-4207 and #492-4509 Electrical manuals and PSB's
1 page 64KB
Used as a kill relay on 1981 B-Series tractors with magneto ignition. The battery style ignition switch controls the relay to ground the magneto ignition.
Starting in 1986 used in the low-oil starter circuit for single-cylinder Kohler engines.
106833 3-terminal relay replaced by a 5 terminal substitute in production because of a parts shortage.
These were replaced by SA121378 service assembly which was replaced by 99-5365 kit.
The 99-5365 kit contained a 48-4700 relay which has been replaced by 116397 relay.
116397 relay used on 1990 312-8 for the low oil starter circuit and 1990 520-H as a starter relay.
82-12o502*C - Correct and Tractor Series
82 -12o502 - Not correct
82-12o502 - Suspicious and not checked or determined yet
106833 Ignition kill relay used on
1978 models 81 -08K801, 81 -10K801, 81 -12K801, 81 -12KS01, 81 -14K801, 81 -14KS01, 81-16B801*C, 81-16BS01*C, 81 -16K801, 81 -16KS01
1979 models 91 -08K801, 91 -08K802, 91 -10K801, 91 -10K802, 91-11B801*C, 91 -12K801, 91 -12K802, 91 -12KS01, 91 -14K801, 91 -14K802, 91 -14KS01, 91-16B801*C, 91-16B802*C, 91-16BS01*C, 91-16BS02*C, 91 -16K801, 91 -16KS01
1980 models 01-11B803*, 02-08BP01*B, 02-11BP02*B, 02-11BX01*B, 02-16BP01*B
1981 models 01-11B804*GT, 02-08BP02*B, 02-08BP03*B, 02-11BP03*B, 02-11BP04*B, 02-11BX02*B, 02-11BX03*B, 02-16BP02*B, 02-16BP03*B
1982 models 01-11BH01*SB, 01 -16KH01, 02-11BH01*SB
1986 and later models used 106833 as a low oil relay
Links to service bulletins
