Switch Ignition Battery Keyed 111216 replaced by 103990 List.jpg 1.0.0
7 Screenshots
1 page from Demystification Guide #492-4509
Image rotated to place the start terminal at the top
1 page 123KB
How to troubleshoot
111216 switch replaced by 103990
5-terminal 3-position key switch for battery ignition
This switch requires a starter solenoid
Tractor Switch Ignition Battery ignition with electric start 103990
(Threads 5/8"-32) 5-terminal 3-position (B-R-A-I-S)
Used 1974-1985
Replaces 111216 5-terminal 3-position
103990 5-terminal 3-position available 06/08 $15.61 from RCPW
Tractor Switch Ignition Battery ignition with electric start 111216
(Threads 5/8"-32) 5-terminal 3-position (B-R-I-A-S)
Used 1986 and 1988-1997
111216 5-terminal 3-position replaced by 103990
Napa and Prime-Line replacement switch 7-01892 (9/16" mounting stem)
Stens replacement switch 430-512 (9/16" mounting stem)
Rotary replacement switch 31-1931 (9/16" mounting stem)
Napa and Prime-Line 5-terminal connector body that uses Packard female spade terminals 7-016034 (With terminals and wire leads 7-01910)
Stens 5-terminal connector body that uses Packard female spade terminals 430-206 (With terminals and wire leads 430-223)
Rotary 5-terminal connector body with terminals and wire leads 31-6662
Bare 5-wire female plastic connector is Kohler 48 155 01 (This also used on the Kohler engine to tractor connector.) Tractor harness male connector is Toro 112185 and illustrated with the low oil switch.
103990 Battery ignition switch used on
1974 models 1-0140*, 1-0145*, 1-0353*, 1-0354*, 1-0356*, 1-0380*, 1 -0385, 1-0390*, 1-0480*, 1-0485*, 1-0490*, 1 -0495, 1-0510*, 1-0611*, 1-0630*, 1-0650*  *****
1974 C-120 8-Speed model 1-0353 - Listed in PSB #301E for 1973-74. Suspect 1973 12hp 8-Speed is wrong ? - Most likely a 1974 model using a 3 key-position switch - 1974 on Belgium list
1974  C-120 8-Speed model 1-0354 - Listed in PSB #301E for 1973-74. Suspect 1973 12hp 8-Speed is wrong ? - Most likely a 1974 model using a 3 key-position switch - 1974 on Belgium list
1975 models 1-0141*, 1 -0357, 1 -0375, 1-0381*, 1-0391*, 1-0395*, 1-0396*, 1-0481*, 1-0491*, 1-0511*, 1-0612*, 1-0631*, 1-0651*  *****
1976 models 61 -07K801, 61 -07K802, 61-08K801*, 61-08K802*, 61-08K803*, 61-08K804*, 61-10K801*, 61-10K802*, 61-10K803*, 61-10K804*, 61-12K801*, 61-12K802*, 61-12K803*, 61-12K804*, 61-12KS01*, 61-12KS02*, 61-12KS03*, 61-12KS04*, 61-16K801*, 61-16K802*, 61-16K803*, 61-16K804*, 61-16KS01*, 61-16KS02*, 61-16KS03*, 61-16KS04*, 61-16OS01*, 61-16OS02*, 61-20KS01*, 61-20KS02*  *****
1977 models 71 -07K801, 71-08K801*, 71-10K801*, 71-12K801*, 71-12KS01*, 71-12KS02*, 71-16K801*, 71-16K802*, 71-16KS01*, 71-16KS02*, 71-16OS01*, 71-20KS01*  *****
1978 models 81-08K801*, 81-10K801*, 81-12K801*, 81-12KS01*, 81-14K801*, 81-14KS01*, 81-16B801*, 81-16BS01*, 81-16K801*, 81-16KS01*, 81-16OS01*, 81-20KS01*  *****
1979 models 91-08K801*, 91-08K802*, 91-10K801*, 91-10K802*, 91-11B801*, 91-12K801*, 91-12K802*, 91-12KS01*, 91-14K801*, 91-14K802*, 91-14KS01*, 91-16B801*, 91-16B802*, 91-16BS01*, 91-16BS02*, 91-16K801*, 91-16KS01*, 91-16OS01*, 91-20KS01*, 91-20KS02*  *****
1980 models 01-08K801*, 01-10K801*, 01-11B803*, 01-12K801*, 01-12KE01*, 01-12KS01*, 01-14E801*, 01-14K801*, 01-14KE01*, 01-14KS01*, 01-16K801*, 01-16KE01*, 01-16KS01*, 01-16OS01*, 01-17K801*, 01-17K802*, 01-17KE01*, 01-17KS02*, 01-20KS00*, 02-08BP01*, 02-11BP02*, 02-11BX01*, 02-16BP01*  *****
1981 models 01-08K802*, 01-10K802*, 01-11B804*, 01-12K802*, 01-12KE02*, 01-14E801*, 01-14K802*, 01-14KE02*, 01-16K802*, 01-16KE02*, 01-17K802*, 01-17KE01*, 01-20KS00*, 02-08BP02*, 02-08BP03*, 02-11BP03*, 02-11BP04*, 02-11BX02*, 02-11BX03*, 02-16BP02*, 02-16BP03*  *****
1982 models 01-08K803*, 01-10K803*, 01-11BH01*, 01-12K803*, 01-14E801*, 01-14KE03*, 01-16KH01*, 01-17K803*, 01-17KE02*, 01-19KE01*, 02-11BH01* *****
1983 models 01-14E801*, 01-14KE04*, 01-17KE03*, 11-08K801, 11-10K801, 11-12K801*, 11-17K801*  *****
1984 models 01-19KE02*, 11-10K802*, 11-12K802*, 11-14KE01*, 11-16K801*, 11-17KE01*  *****
1985 models 21-10K801*, 21-12K801*, 21-14K801*, 21-14KE01*, 31-16K801*, 31-17K801*, 31-17KE01*  *****
111216 Battery ignition switch used on
1986 models 21 - 08K801, 21 - 08K802, 21-10K802*, 21-10K803*, 21-12K802*, 21-12K803*, 21-12KE01*, 21-12KE02*, 31-14K801*, 31-16K802*, 31-17K802*, 31-17KE02*, 31 - 20KE01, B1-12R801*, C1-12R801*  *****
1987 111216 switch not used in 1987
1988 models 31-16OE01*, 31-18OE01*, 31-20OE01*, B1-16O801*, C1-20OE01*, E1 -12K801, E1-18OE01*, Z1-24OE01*  *****
1989 models 21 -10K806, 21 -12K806, 31 -14K804, 31-16O801*, 31-18OE02*, 31-20OE02*, B1-16O802*, C1-20OE02*, E1 -12K802, E1-18OE02*, Z1-24OE02*  *****
1990 models 31 -10K801, 31 -12K801, 31 -12KE01, 31-16O802*, 41-16OE01*, 41-20O801*, 41-20OE01*, R1 -12K801, R1 -12K802, R1-16O801*, R1-16O802*, R1-18OE01*, R1-18OE02*, Z1-24OE03*  *****
1991 models 31 -10K802, 31 -12K802, 31-16O803*, 32-10B502*, 32-10BE02*, 32-12B5A3*, 32-12BEA3*, 32 -12O502, 32 -12OE02, 41-20OE02*, 51 -12KE01, 51-16OE01*, R1-20OE01*, S2-12B502*, Z1-24OE04*  *****
1992 models 41-20OE03*, R1-20OE02*  *****
1992 models 31 -10K803, 31 -12K804, 31-16O804*, 32-10B503*, 32-10BE03*, 32 -12O503, 32-12OE03*, 51 -12KE02, 51-16OE02*, R1 -12K804, R1-16O804*, Z1-24OE05*  *****
1993 models 73501*, 73520e*  *****
1993 models 7 3380, 7 3400, 73420*, 73421*, 73440*, 74140*  *****
1994 models 73520*, 74140*  *****
1994 models 7 3380, 7 3400, 7 3401, 73420*, 73421*, 73440*, 73501*  *****
1995 models 73520e, 74140*Z  *****
1995 models 7 3400, 7 3401 x 373420* x 3, 73421* x 2, 73440* x 2, 73501* x 4, 73520e*  *****
1996 models 7 3400, 7 3401, 73420*, 73421*, 73423*, 73501*, 73502*, 73521*e  *****
1997 models 73422*, 73423*, 73441*e, 73502*, 73521*e  *****
  • Thanks 3
