From the Demystification Guide #492-4509
1 page 127.8KB
Page 3-10
Gage Tachometer 113467 113476 78-0060
Suspect the 113476 is a typo and should be 113467
113467 Tachometer used on - (replaced by 78-0060)
1988 models 31-16OE01, 31-18OE01, 31-20OE01, C1-20OE01
1989 models 31-18OE02, 31-20OE02, C1-20OE02
1990 models 41-20O801, 41-20OE01
78-0060 Tachometer used on
1991 models 41-20OE02, R1-20OE01*
1992 models 41-20OE03, R1-20OE02*
1993 models 73501, 73520
1994 models 73501, 73520
1995 models 73501 x 4, 73520 x 2
1996 models 73501, 73502, 73521
1997 models 73502, 73521
Mistake in 492-4509 manual - The 113476 and 78-0060 tachometer does not get it's signal on the grey wire from the B+ terminal of the voltage regulator. This is also incorrect on page 3-10 describing the tachometer's operation.
The grey wire comes from one of the regulator's AC terminals. If the tach will not work try the other AC terminal. Only one of them has a tach signal.
