Engine Kohler K181 8hp Spec 30100-30848 IPL #TP-2045-B.pdf
Illustrated parts lists
Covers Spec No's 30100-30848
88 pages 5.84MB
The following engines have the spark advance camshaft
K181, Suffix prior to “D”
K181 (8 HP or 6KW)
1964 model 854 - Uses K181S-30108a
1965 model 855 - Uses K181S-30108a
1965 model 875 - Uses K181S-30108a
1966 model 856 - Uses K181S-30108d
1966 model 876 - Uses K181S-30108d
1967 model 857 - Uses K181S-30108d
1967 model 867 - Uses K181S-30108d
1967 model 877 - Uses K181S-30108d
1968 Commando 8 model 1-4831 - Uses K181S-30108d
1969 Commando V8 model 1-4841 - Uses KV181S-37108b - not in ipl
1969 Charger V8 model 1-7841 - Uses KV181S-37108b - not in ipl
1970 Commando V8 model 1-4851 - Uses KV181S-37116b - not in ipl
1972 Commando 800 4-Speed model 1-0110 - Uses K181S-30461d
1972 Raider 8 model 1-0330 - Uses K181S-30461d
1973 8hp 4-Speed model 1-0120 - Uses K181S-30461d
1973 8hp 4-Speed model 1-0130 - Uses K181S-30461d
1973 8hp 8-Speed model 1-0370 - Uses K181S-30461d
1974 B-80 4-Speed model 1-0140 - Uses K181S-30461d
1974 B-80 4-Speed model 1-0145 - Uses K181S-30461d
1975 B-80 4-Speed model 1-0141 - Uses K181S-30629d
1976 B-80 8-Speed model 61-08K801 - Uses K181S-30629d - Incorrectly named a B-60 @ Toro
1976 B-80 8-Speed model 61-08K802 - Uses K181S-30629d - Incorrectly named a B-60 @ Toro
1976 B-80 8-Speed model 61-08K803 - Uses K181S-30629d
1976 B-80 8-Speed model 61-08K804 - Uses K181S-30629d - Incorrectly named a B-60 @ Toro
1977 B-80 8-Speed model 71-08K801 - Uses K181S-30629d
1978 C-81 8-Speed model 81-08K801 - Uses K181S-30700d
1979 C-81 8-Speed model 91-08K801 - Uses K181S-30700d
1979 C-81 8-Speed model 91-08K802 - Uses K181S-30700d
1980 C-85 8-Speed model 01-08K801 - Uses K181S-30743d - Incorrectly named a C-81 @ Toro
1981 C-85 8-Speed model 01-08K802 - Uses K181S-30743d - Incorrectly named a C-81 @ Toro
1982 C-85 8-Speed model 01-08K803 - Uses K181S-30743d
1983 C-85 8-Speed model 11-08K801 - Uses K181S-30803
The following were supplied to Wheel Horse according to Kohler records
K181-301046 - ? - 30104 is in the ipl
K181-30108 - 1965, 1962, 1963, 1964, 1965, 1966, 1967, 1968
K181-30461 - 1972, 1973, 1974
K181-30518 - ? - Is in the ipl
K181-30584 - ? - Is in the ipl
K181-30629 - 1975, 1976, 1977
K181-30700 - 1978, 1979 - Not listed by Kohler for Wheel Horse but is in the ipl
K181-30743 - 1980, 1981, 1982
K181-30803 - 1983
