Illustrated parts lists
78 pages 4.13MB
K321 (14hp or 10.4KW)
1969 GT-14 model 1-7441 uses K321S-60125b according to Toro & PSB301e. Should be K321-6010
1970 GT-14 model 1-7451 uses K321S-60125b
1970 GT-14 model 1-7452 uses K321S-60125b
1970 GT-14 model 1-7453 uses K321S-60125b
1971 Bronco 14 model 1-0420 uses K321S-60124b
1971 Bronco 14 model 1-0421 uses K321S-60124b
1971 GT-14 model 1-0500 uses K321S-60125b
1971 GT-14 model 1-0501 uses K321S-60125b
1972 Raider 14 model 1-0320 uses K321S-60137a
1972 Bronco 14 model 1-0422 uses K321S-60137a
1972 Bronco 14 model 1-0423 uses K321S-60137a
1972 GT-14 model 1-0502 uses K321S-60149a
1972 GT-14 model 1-0503 uses K321S-60149a
1973 GT-14 model 1-0502-8 uses K321S-60149a
1973 14hp 8-Speed model 1-0340 uses K321S-60137d
1973 14hp Automatic model 1-0430 uses K321S-60137d
1973 14hp Automatic model 1-0435 uses K321S-60137d
1978 C-141 8-Speed model 81-14K801 uses K321AS-60322d
1978 C-141 Automatic model 81-14KS01 uses K321AS-60322d
1979 C-141 8-Speed model 91-14K801 uses K321AS-60322d
1979 C-141 8-Speed model 91-14K802 uses K321AS-60322d
1979 C-141 Automatic model 91-14KS01 uses K321AS-60322d
1980 C-145 8-Speed model 01-14K801 uses K321AS-60362d
1980 C-145 Automatic model 01-14KE01 uses K321AS-60362d
1980 C-145 Automatic model 01-14KS01 uses K321AS-60362d
1981 C-145 8-Speed model 01-14K802 uses K321AS-30373d - Wrong 30373 spec number listed @ Toro - should be 60373
1981 C-145 Automatic model 01-14KE02 uses K321AS-30373d - Wrong 30373 spec number listed @ Toro - should be 60373
1982 C-145 Auto model 01-14KE03 uses K321AS-60373d
1983 C-145 Auto model 01-14KE04 uses K321AS-60373d
1985 314-8 model 21-14K801 uses K321S-60424
1985 314-A model 21-14KE01 uses K321S-60424
1986 414-8 model 31-14K801 uses K321S-60440 -- First with low oil switch
The following were supplied to Wheel Horse according to Kohler records
K321-6010 - 1969
K321-60124 - 1971
K321-60125 - 1969, 1970, 1971
K321-60137 - 1972, 1973
K321-60149 - 1972, 1973
K321-60279 - ?
K321-60322 - 1978, 1979
K321-60362 - 1980
K321-60373 - 1981, 1982, 1983 - Wrong 30373 spec number listed @ Toro - should be 60373 for 1981 and 1982
K321-60414 - ?
K321-60417 - ?
K321-60424 - 1985
K321-60440 - 1986 -- First with low oil switch
