41 pages 3.74MB
This ipl is shared by similar models so each item may have more than one part number but fails to identify what model uses what part.
Original IPL #810480R1
On the Belgium list
4-pinion differential @ Toro not correct so replaced the ipl with the correct pages
Modified wiring from owner manual #810473R1 Revised Color pdf
1 page 701KB
Magneto ignition with 3 amp unregulated charging system
Demystification Guide not correct - shows 15 amp stator.
Tractor weight 553 lbs.
Transmission drive belt 78-7100 replaced by 7473 - HB x 81.9" or 5/8" x 81.9"
3 pages 118.47KB
1987 414-8 model 31-14K802 with magneto ignition and 3 amp unregulated charging system
1987 serial numbers that have shown up for the 31-14K802
20497
20751
21124
21339
21370
28077
