1 page 97.78KB
Dated February 9, 1998
42in
Mower Rotary 1993 42in SD model 78345 Serial 3900001-3999999
Mower Rotary 1994 42in SD model 78345 Serial 4900001-4999999
Mower Rotary 1995 42in SD model 78345 Serial 5900001-5999999
Mower Rotary 1996 42in SD model 78345 Serial 6900001-6999999
Mower Rotary 1997 42in SD model 78345 Serial 7900001-7999999
Mower Rotary 1998 42in SD model 78345 Serial 8900001-8999999
Mower Rotary 1999 42in SD model 78345 Serial 9900001-9999999
Mower Rotary 2000 42in SD model 78345 Serial 200000001-200999999
Mower Rotary 2001 42in SD model 78345 Serial 210000001-210999999
Mower Rotary 2002 42in SD model 78345 Serial 220000001-220999999
Mower Rotary 2003 42in SD model 78345 Serial 230000001-230999999
Mower Rotary 2004 42in SD model 78345 Serial 240000001-240999999
Mower Rotary 2005 42in SD model 78345 Serial 250000001-250999999
Mower Rotary 2006 42in SD model 78345 Serial 260000001-260999999
Mower Rotary 2007 42in SD model 78345 Serial 270000001-270999999
Mower Rotary 2008 42in SD model 78345 - None made
Mower Rotary 2009 42in SD model 78345 Serial 290000001-290999999
Mower Rotary 2010 42in SD model 78345 Serial 310000001-310999999
Mower Rotary 2011 42in SD model 78345 Serial 311000001-311999999
Mower Rotary 2012 42in SD model 78345 Serial 312000001-312999999
Mower Rotary 2013 42in SD model 78345 - None made
Mower Rotary 2014 42in SD model 78345 Serial 314000001-314999999
Mower Rotary 1992 42in SD model 07-4XVC01 Vacuum Serial 2000001-2999999
Mower Rotary 1993 42in SD model 79301 Vacuum Serial 3900001-3999999
Mower Rotary 1994 42in SD model 79301 Vacuum Serial 4900001-4999999
Mower Rotary 1995 42in SD model 79301 Vacuum Serial 5900001-5999999
Mower Rotary 1996 42in SD model 79301 Vacuum Serial 6900001-6999999
Mower Rotary 1997 42in SD model 79301 Vacuum Serial 7900001-7900475
Mower Rotary 1997 42in SD model 79301 Vacuum Serial 7900476-7999999 (Do not know the reason for the serial # break)
Mower Rotary 1998 42in SD model 79301 Vacuum Serial 8900001-8999999
Mower Rotary 2000 42in SD model 79301 Vacuum Serial 200000001-200999999
Mower Rotary 2001 42in SD model 79301 Vacuum Serial 210000001-210999999
Mower Rotary 2002 42in SD model 79301 Vacuum Serial 220000001-220999999
Mower Rotary 2003 42in SD model 79301 Vacuum Serial 230000001-230999999
Mower Rotary 2004 42in SD model 79301 Vacuum Serial 240000001-240999999
Mower Rotary 2005 42in SD model 79301 Vacuum Serial 250000001-250999999
Mower Rotary 2006 42in SD model 79301 Vacuum Serial 260000001-260999999
Mower Rotary 2007 42in SD model 79301 Vacuum Serial 270000001-270999999
Mower Rotary 2010 42in SD model 79301 Vacuum Serial 310000001-310999999
Mower Rotary 2012 42in SD model 79301 Vacuum Serial 312000001-312999999
48in
Mower Rotary 1998 48in SD model 78361 Serial 8900001-8999999
Mower Rotary 1999 48in SD model 78361 Serial 9900001-9999999
Mower Rotary 2000 48in SD model 78361 Serial 200000001-200999999
Mower Rotary 2001 48in SD model 78361 Serial 210000001-210999999
Mower Rotary 2002 48in SD model 78361 Serial 220000001-220999999
Mower Rotary 2003 48in SD model 78361 Serial 230000001-230999999
Mower Rotary 2004 48in SD model 78361 Serial 240000001-240999999
Mower Rotary 2005 48in SD model 78361 Serial 250000001-250999999
Mower Rotary 2006 48in SD model 78361 Serial 260000001-260999999
Mower Rotary 2007 48in SD model 78361 Serial 270000001-270999999
Mower Rotary 2008 48in SD model 78361 - None built
Mower Rotary 2009 48in SD model 78361 Serial 290000001-290999999
Mower Rotary 2010 48in SD model 78361 Serial 310000001-310999999
Mower Rotary 2011 48in SD model 78361 Serial 311000001-311999999
Mower Rotary 2012 48in SD model 78361 Serial 312000001-312999999
Mower Rotary 1992 48in SD model 07-4XVC01 Vacuum Serial 2000001-2999999
Mower Rotary 1993 48in SD model 79301 Vacuum Serial 3900001-3999999
Mower Rotary 1994 48in SD model 79301 Vacuum Serial 4900001-4999999
Mower Rotary 1995 48in SD model 79301 Vacuum Serial 5900001-5999999
Mower Rotary 1996 48in SD model 79301 Vacuum Serial 6900001-6999999
Mower Rotary 1997 48in SD model 79301 Vacuum Serial 7900001-7900475
Mower Rotary 1997 48in SD model 79301 Vacuum Serial 7900476-7999999 (Do not know the reason for the serial # break)
Mower Rotary 1998 48in SD model 79301 Vacuum Serial 8900001-8999999
Mower Rotary 2000 48in SD model 79301 Vacuum Serial 200000001-200999999
Mower Rotary 2001 48in SD model 79301 Vacuum Serial 210000001-210999999
Mower Rotary 2002 48in SD model 79301 Vacuum Serial 220000001-220999999
Mower Rotary 2003 48in SD model 79301 Vacuum Serial 230000001-230999999
Mower Rotary 2004 48in SD model 79301 Vacuum Serial 240000001-240999999
Mower Rotary 2005 48in SD model 79301 Vacuum Serial 250000001-250999999
Mower Rotary 2006 48in SD model 79301 Vacuum Serial 260000001-260999999
Mower Rotary 2007 48in SD model 79301 Vacuum Serial 270000001-270999999
Mower Rotary 2010 48in SD model 79301 Vacuum Serial 310000001-310999999
Mower Rotary 2012 48in SD model 79301 Vacuum Serial 312000001-312999999
