1 page 90.12KB
Dated May 20, 1993
Adapter kit 79-7770 instructions #3315-378
2 pages 126KB
Adapter kit 79-7780 instructions #3315-379
2 pages 109KB
42in
Mower Rotary 1992 42in SD model 07-4XVC01 Vacuum Serial 2000001-2999999
Mower Rotary 1993 42in SD model 79301 Vacuum Serial 3900001-3999999
Mower Rotary 1994 42in SD model 79301 Vacuum Serial 4900001-4999999
Mower Rotary 1995 42in SD model 79301 Vacuum Serial 5900001-5999999
Mower Rotary 1996 42in SD model 79301 Vacuum Serial 6900001-6999999
Mower Rotary 1997 42in SD model 79301 Vacuum Serial 7900001-7900475
Mower Rotary 1997 42in SD model 79301 Vacuum Serial 7900476-7999999 (Do not know the reason for the serial # break)
Mower Rotary 1998 42in SD model 79301 Vacuum Serial 8900001-8999999
Mower Rotary 1999 42in SD model 79301 Vacuum Serial 9900001-9999999
Mower Rotary 2000 42in SD model 79301 Vacuum Serial 200000001-200999999
Mower Rotary 2001 42in SD model 79301 Vacuum Serial 210000001-210999999
Mower Rotary 2002 42in SD model 79301 Vacuum Serial 220000001-220999999
Mower Rotary 2003 42in SD model 79301 Vacuum Serial 230000001-230999999
Mower Rotary 2004 42in SD model 79301 Vacuum Serial 240000001-240999999
Mower Rotary 2005 42in SD model 79301 Vacuum Serial 250000001-250999999
Mower Rotary 2006 42in SD model 79301 Vacuum Serial 260000001-260999999
Mower Rotary 2007 42in SD model 79301 Vacuum Serial 270000001-270999999
Mower Rotary 2010 42in SD model 79301 Vacuum Serial 310000001-310999999
Mower Rotary 2012 42in SD model 79301 Vacuum Serial 312000001-312999999
Vac-Bagger Adapter Kit 79-7770 fits
Mower Rotary 1985 42in SD model 05-42MS04
Mower Rotary 1986 42in SD model 05-42MS05
Mower Rotary 1987 42in SD model 05-42MS05
Mower Rotary 1988 42in SD model 05-42MS05
Mower Rotary 1988 42in SD model E5-42MS01 - Export model
Mower Rotary 1989 42in SD model 15-42SC01
Mower Rotary 19xx 42in SD model B5-42MS03 - Export model - No record
Mower Rotary 19xx 42in SD model B5-42MS04 - Export model - No record
(Use installation instructions #3315-378)
48in
Mower Rotary 1992 48in SD model 07-4XVC01 Vacuum Serial 2000001-2999999
Mower Rotary 1993 48in SD model 79301 Vacuum Serial 3900001-3999999
Mower Rotary 1994 48in SD model 79301 Vacuum Serial 4900001-4999999
Mower Rotary 1995 48in SD model 79301 Vacuum Serial 5900001-5999999
Mower Rotary 1996 48in SD model 79301 Vacuum Serial 6900001-6999999
Mower Rotary 1997 48in SD model 79301 Vacuum Serial 7900001-7900475
Mower Rotary 1997 48in SD model 79301 Vacuum Serial 7900476-7999999 (Do not know the reason for the serial # break)
Mower Rotary 1998 48in SD model 79301 Vacuum Serial 8900001-8999999
Mower Rotary 1999 48in SD model 79301 Vacuum Serial 9900001-9999999
Mower Rotary 2000 48in SD model 79301 Vacuum Serial 200000001-200999999
Mower Rotary 2001 48in SD model 79301 Vacuum Serial 210000001-210999999
Mower Rotary 2002 48in SD model 79301 Vacuum Serial 220000001-220999999
Mower Rotary 2003 48in SD model 79301 Vacuum Serial 230000001-230999999
Mower Rotary 2004 48in SD model 79301 Vacuum Serial 240000001-240999999
Mower Rotary 2005 48in SD model 79301 Vacuum Serial 250000001-250999999
Mower Rotary 2006 48in SD model 79301 Vacuum Serial 260000001-260999999
Mower Rotary 2007 48in SD model 79301 Vacuum Serial 270000001-270999999
Mower Rotary 2010 48in SD model 79301 Vacuum Serial 310000001-310999999
Mower Rotary 2012 48in SD model 79301 Vacuum Serial 312000001-312999999
Vac-Bagger Adapter Kit 79-7780 fits
Mower Rotary 1988 48in SD model E5-48SC01 - Export model
Mower Rotary 1989 48in SD model 15-48SC01
Mower Rotary 1989 48in SD model F5-48SC01 - Export model
(Use installation instructions #3315-379)
Vac-Bagger Adapter Kit 79-7790 fits
Mower Rotary 1985 48in SD model 05-48MS04
Mower Rotary 1986 48in SD model 05-48MS05
Mower Rotary 1987 48in SD model 05-48MS05
Mower Rotary 1988 48in SD model 05-48MS05
(Use installation instructions #3315-380)
