Transmission Gear Uni-drive 8-speed 1.125in axle 8-pinion 92-8708 1997-2005 & 2007 IPL.pdf
Model 92-8708 - (Had this as model 94-6671)
1-1/8" axles (Uses 2 105875 axles 13" long and 937108 Woodruff #22 keys - 1/4" x 1-3/8")
8-pinion differential eight-speed
Double axle seals
3 pages 842.49KB
Used 1997-2005 and 2007
1997 314-8 model 73402
1997 416-8 model 73422
1997 416-8e model 73441
1998 314-8 model 73448
1999 314-8 model 73449
2000 314-8 model 73449
2001 314-8 model 73449
2002 315-8 model 73450
2003 315-8 model 73450
2004 315-8 model 73450
2005 GT-Classic model 73450
2007 GT-Classic model 73450
