Transmission Gear Uni-drive 8-speed 1.125in axle 4-pinion 92-8707 1997-2001 IPL.pdf
Model 92-8707 - (Had this as model 94-6670)
4 pinion differential eight-speed
Double axle seals
3 pages 841.06KB
Used 1997-2001
1997 312-8 model 73363
1998 312-8 model 73428
1999 312-8 model 73429
2000 312-8 model 73429
2001 312-8 model 73429
