Transmission Gear Uni-drive 8-speed 1.125in axle 4-pinion 92-8707 1993-1996 IPL.pdf
Model 92-8707
4-pinion differential eight-speed
Double axle seals
4 pages 1.09MB
Toro lists the 92-8707 transmission with 8 pinions and double axle seals for 1993-2005 and 2001
The parts lists show the 92-8707 transmission used only in the following models
1993 312-8e model 73380 - Original IPL n/a (This model missed in attachment list and belt charts)
1994 312-8 model 73362
1995 312-8 model 73362
1996 312-8 model 73362
1996 312-8 model 73363
1997-2001 models use 94-6670 (4-pinion) transmission
or
1997-2005 and 2007 use 94-6671 (8-pinion) transmission
