Model 92-8708
1-1/8" axles (Uses 2 105875 axles 13" long and 937108 Woodruff #22 keys - 1/4" x 1-3/8")
8-pinion differential eight-speed
Double axle seals
4 pages 1.08MB
e = Export models
Toro lists the 92-8708 transmission with 8 pinions and double axle seals for 1993-2005 and 2007
The parts lists show the 92-8708 transmission used only in the following models
1994 312-8 model 73380 - Toro lists this model as using 92-8707 trasmission which is not correct according to IPL #3316-897
1994 314-8 model 73400
1994 416-8 model 73420
1994 416-8e model 73440
1995 314-8 model 73400
1995 416-8 model 73420 serial 5900000-5900614 - A guess because the original ipl n/a
1995 416-8 model 73420 serial 5900615-5900714
1995 416-8 model 73420 serial 5900715-5999999
1995 416-8e model 73440 serial 5900000-5900222
1995 416-8e model 73440 serial 5900223-5999999
1996 314-8 model 73400
1996 314-8 model 73402 - Toro lists this model as using 92-8707 trasmission with 4 pinions and double axle seals.
1996 416-8 model 73420
1996 416-8 model 73422 - Toro lists this model as using 92-8707 trasmission with 4 pinions and double axle seals.
1996 416-8 model 73441
1997-2001 models use 94-6670 (4-pinion) transmission
or
1997-2005 and 2007 use 94-6671 (8-pinion) transmission
