1986 Model 110996
4 pages 2MB
1991 Model 110995
1-1/8" axles (Uses 2 105875 axles 13" long and 937108 Woodruff #22 keys - 1/4" x 1-3/8") [From Toro ipl 310-8 models sn 11752-11755 use 937097 Woodruff #15 key 1/4" x 1"]
8 one-piece pinion differential eight-speed
Single axle seal
4 pages 189.80KB
110995 used 1985-1993 with 1-1/8" axles
1985 310-8 model 21-10K801 - * Uses 1533 differential carrier bearings * (1-1/2x2-1/2x1/2in.) -
(Serial numbers 11752, 11753, 11754 and 11755 used the 110995 transmission with 8 pinions and 1-1/8" axles - Source 1991 ipl)
1985 314-8 model 21-14K801 - * Uses 1533 differential carrier bearings * (1-1/2x2-1/2x1/2in.) - Guessing this one is correct
1985 416-8 model 31-16K801 - * Uses 1533 differential carrier bearings * (1-1/2x2-1/2x1/2in.)
1985 417-8 model 31-17K801 - * Uses 1533 differential carrier bearings * (1-1/2x2-1/2x1/2in.)
1986 414-8 model 31-14K801 - * Uses 111199 differential carrier bearings * (SKF 6008-C3 40x68x15mm)
1986 416-8 model 31-16K802 - * Uses 111199 differential carrier bearings * (SKF 6008-C3 40x68x15mm)
1986 417-8 model 31-17K802 - * Uses 111199 differential carrier bearings * (SKF 6008-C3 40x68x15mm)
1987 414-8 model 31-14K802 - * Uses 111199 differential carrier bearings * (SKF 6008-C3 40x68x15mm)
1987 416-8 model 31-16K803 - * Uses 111199 differential carrier bearings * (SKF 6008-C3 40x68x15mm)
1987 418-8 model 31-18K801 - * Uses 111199 differential carrier bearings * (SKF 6008-C3 40x68x15mm)
1988 414-8 model 31-14K803 - * Uses 111199 differential carrier bearings * (SKF 6008-C3 40x68x15mm)
1988 416-8 model 31-16K804 - * Uses 111199 differential carrier bearings * (SKF 6008-C3 40x68x15mm)
1989 414-8 model 31-14K804
1989 416-8 model 31-16O801
1990 312-8 model 31-12K801 - Toro lists this model as using the 110996 with 1" axle 4-pinion differential which is wrong
1990 312-8e model R1-12K802 - Exported model
1990 316-8e models R1-16O801 and R1-16O802 - Exported models
1990 416-8 model 31-16O802
1990 520-8 model 41-20O801
1991 312-8 model 31-12K802 Serial 1900001-1999999
1991 416-8 model 31-16O803 Serial 1900001-1999999
1992 312-8 model 31-12K804 Serial 2900001-2999999
1992 312-8e model R1-12K804 Serial 2900001-2999999 - Exported model
1992 316-8e model R1-16O804 Serial 2900001-2999999 - Exported model
1992 416-8 model 31-16O804 Serial 2900001-2999999
Toro lists the following as using 92-8708 transmission with 8 pinions and double axle seals but the parts lists have 110995 with 8 pinions and a single axle seal.
1993 314-8 model 73400 Serial 3900001-3999999
1993 416-8 model 73420 Serial 3900001-3999999
1993 416-8e model 73440 Serial 3900001-3999999 - Exported model
