Transmission Gear Uni-drive 8-speed 1.125in axle 8-pinion 103916 1978-1984 IPL.pdf
Model 103916
Illustrated parts list
7 pages 319.92KB
1-1/8" axle (Uses 2 105875 axles 13" long and 937108 Woodruff #22 keys - 1/4" x 1-3/8") [From 1980-81 Toro ipl some C-85 and C-105 models use 937097 Woodruff #15 key 1/4" x 1"]
8 one-piece pinion differential eight-speed
Uses long 937108 or #22 Woodruff key (1/4" x 1-3/8") in wheel/axle hub. Some places the key is 937128 and may be a typo
Used 1978-1984
1978 C-81 8-speed model 81-08K801
1978 C-101 8-speed model 81-10K801
1978 C-121 8-speed model 81-12K801
1978 C-141 8-speed model 81-14K801
1978 C-161 8-speed model 81-16K801
1978 C-161 Twin 8-speed model 81-16B801
1979 C-81 8-speed models 91-08K801, 91-08K802
1979 C-101 8-speed models 91-10K801, 91-10K802
1979 C-111 8-speed model 91-11B801
1979 C-121 8-speed models 91-12K801 91-12K802
1979 C-141 8-speed models 91-1kK801, 91-14K802
1979 C-161 8-speed model 91-16K801 - Listed @ Toro as using model 5086
1979 C-161 Twin 8-speed model 91-16B801 - Listed @ Toro as using model 5086
1979 C-161 Twin 8-speed model 91-16B802 - Listed @ Toro as using model 5086
1980 C-85 8-speed model 01-08K801 (This is incorrectly named a C-81 at Toro)
1980 C-105 8-speed model 01-10K801
1980 C-125 8-speed model 01-12K801
1980 C-145 8-speed model 01-14K801
1980 C-165 8-speed model 01-16K801
1980 C-175 Twin 8-speed model 01-17K801
1981 C-85 8-speed model 01-08K802 (This is incorrectly named a C-81 at Toro)
1981 C-105 8-speed model 01-10K802
1981 C-125 8-speed model 01-12K802
1981 C-145 8-speed model 01-14K802
1981 C-165 8-speed model 01-16K802
1981 C-175 Twin 8-speed model 01-17K802
1982 C-85 8-speed model 01-08K803
1982 C-105 8-speed model 01-10K803
1982 C-125 8-speed model 01-12K803
1982 C-175 Twin 8-speed model 01-17K803
1983 C-85 8-speed model 11-08K801
1983 C-105 8-speed model 11-10K801
1983 C-125 8-speed model 11-12K801
1983 C-175 Twin 8-speed model 11-17K801
1984 C-105 8-speed model 11-10K802 - Some used alternate inner axle bearing See PSB #369
1984 C-125 8-speed model 11-12K802 - Some used alternate inner axle bearing See PSB #369
1984 C-165 8-speed model 11-16K801 - Some used alternate inner axle bearing See PSB #369
