Transmission Gear Uni-drive 8-speed 1.125in axle 8-pinion 5091 1973-1976 IPL.pdf
Model 5091
Illustrated parts list
1-1/8" axle (Uses 2 of 102764 axles 11-5/8" long and 937022 Woodruff #15 keys - 1/4" x 1") [937002 replaced by 937022 - May be a typo]
8 one-piece pinion differential eight-speed
2 pages 428.91KB
Used 1973-1976 in
1973 12hp 8-speed model 1-0355
1974 C-100 8-speed model 1-0390
1974 C-120 8-speed model 1-0353
1974 C-120 8-speed model 1-0354
1974 C-120 8-speed model 1-0356
1974 C-160 8-speed model 1-0380
1974 C-160 8-speed model 1-0385
1975 C-100 8-speed model 1-0391
1975 C-120 8-speed model 1-0357
1975 C-120 8-speed model 1-0375
1975 C-120 8-speed model 1-0395
1975 C-120 8-speed model 1-0396
1975 C-160 8-speed model 1-0381
1976 B-60 8-speed model 61-07K801
1976 B-60 8-speed model 61-07K802
1976 B-80 8-speed model 61-08K801
1976 B-80 8-speed model 61-08K802
1976 B-80 8-speed model 61-08K804
1976 B-100 8-speed model 61-10K801
1976 B-100 8-speed model 61-10K802
1976 B-100 8-speed model 61-10K804
1976 C-120 8-speed model 61-12K801
1976 C-120 8-speed model 61-12K802
1976 C-120 8-speed model 61-12K804
1976 C-160 8-speed model 61-16K801
1976 C-160 8-speed model 61-16K802
1976 C-160 8-speed model 61-16K804
