Model 5086
1" axles - 2 of 5961 11-5/8" long
4 one-piece pinion differential eight-speed
The 8hp and 10hp models in this parts list used the 5086 transmission.
Used in
1972 Raider 8 model 1-0330
1972 Raider 10 model 1-0301
1973 8hp 8-speed model 1-0370
1973 10hp 8-speed model 1-0365
1973 Raider 10 8-speed model 1-0360
(1979 C-161 8-speed model 91-16K801 Listed @ Toro but not correct - Uses model 103916)
(1979 C-161 Twin 8-speed model 91-16B801 Listed @ Toro but not correct - Uses model 103916)
(1979 C-161 Twin 8-speed model 91-16B802 Listed @ Toro but not correct - Uses model 103916)
1980 1100 Special model 01-11B803
1981 GT-2500 8-speed model 01-11B804
1982 GT-1142 8-speed model A1-114201
1982 GT-1642 Twin 8-speed model A1-164201
1982 SB-421 8-speed model 01-11BH01
1982 SK-486 8-speed model 01-16KH01
1983 GT-1142 8-speed model A1-114202
1983 GT-1642 Twin 8-speed model A1-164202
1984 GT-1100 8-speed model A1-11B801 - Some used alternate inner axle bearing See PSB #369
1984 GT-1600 Twin 8-speed model A1-16B801 - Some used alternate inner axle bearing See PSB #369
