Transmission Gear Uni-drive 6-speed 1.125in axle 10-pinion LS 5060 1967-1968 IPL.pdf
Model 5060
Illustrated parts list
2 pages 2.51MB
1-1/8`` axles Uses 7202 replaced by 121384 12" right axle and 7203 11-1/4" left axle and 937022 Woodruff #15 keys - 1/4" x 1") [937002 replaced by 937022 - May be a typo]
Axle 101511 also shows as being replaced by 121384
10 pinion limited slip differential six-speed
5060 has an extension on the filler plug - no dipstick
6-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section III of the service manual.
Aluminum side plates on the 5060 differential...steel side plates on the 5071
5060 used in
1967 867
1967 1067
1967 1267
1968 Raider 9 model 1-6931
1968 Raider 12 model 1-6231
  • Excellent 1
